7i77 lost connection while encoder counts (PREEMPT-RT)
- lonnox
08 Jul 2025 14:46 #331526
by lonnox
Replied by lonnox on topic 7i77 lost connection while encoder counts (PREEMPT-RT)
The BIOS give me the option to limit all PCI E to gen1 speed. There is no option/feature like XMP/EXPO option, but one to set the ram speed manually, so i set it to a lower one.
I also tried to use different pci slot for the 6i25 (for the graphics card, there is only one slot available).
I also have an M2 SSD installed, that also uses the pci lanes if i get it right. Tried to use a HDD with new live image installed instead.
But no luck.
rtai on the other hand runs absolutely stable, i already drove more than 1km with the test equipment
But no luck.
- Thank you received: 7490
08 Jul 2025 22:06 #331547
Replied by tommylight on topic 7i77 lost connection while encoder counts (PREEMPT-RT)
OK, that only leaves the memory modules, so if there are two, try yanking one out and testing, then the other one and test again.
Explanation for some of my replies:
I use a lot of Ryzen PC's, including this one i am typing on:
forum.linuxcnc.org/show-your-stuff/55173...thers-company#331546
And the rest on that topic, one thing i found out the hard way is that PCI-E issues will sometimes show as memory errors on Linux boot and DMESG, and easy to reproduce by using different GEN devices, mostly graphic cards, especially if using riser cable for it.
- lonnox
09 Jul 2025 06:31 #331558
by lonnox
Dude, your machines look awesome by the way!
there is only one RAM module in the PC, but i tried to swap it with a module from another PC. Both module have different speeds, sizes and manufactors. The same is for a second graphics card i tried.
But again without luck.
Wish i had another Ryzen CPU for testing but i haven't.
Time to create page: 0.449 seconds
