5 axis milling machine with 7i96s
1 year 3 months ago #331820 by PCW
Hi PCW,
I found a card locally that seems similar to the Sainsmart breakout you had mentioned. I'll add the link below. It says its for Mach3 and LinuxCnc, would this work with my Mesa 7i96s. Thanks so much for your help. Interface Board CNC 5 Axis
Yes, that looks exactly like a Sainsmart ST-V2 so 7i96s_5abobd.bin firmware
will work with that.
1 year 3 months ago #331843 by Gautham
Thank you so much PCW
1 year 2 months ago - 1 year 2 months ago #333891 by Gautham
Hi again,So I finally got this BoB,  and I have wired up everything according to this video tutorial I found, but I don't know how to configure my B-axis to run through the BoB on LinuxCNC. I also managed to flash the 7i96s_5abobd.bin firmware to the mesa card but I'm not sure how to proceed on LinuxCNC
Thank you so much for your help.
Last edit: 1 year 2 months ago by Gautham. Reason: adding some more info
1 year 2 months ago #333908 by PCW
I would probably use pncconfs discovery option so pncconf knows about the
additional stepgens so you can configure the B axis.
1 year 2 months ago #333936 by Gautham
Thanks for the reply PCW. I was going through pncconfs and I couldn't find anything like discovery(Im new to LinuxCNC). While going through pncconfs I was a little confused because I flashed the 7i96s_5abobd.bin file but I couldn't find this as an option in pncconf as you can see in the image below. Anyways, I tried all three of the options that were there and none of them gave me the option of adding the BoB. Thank you for your help
image missing https://i.ibb.co/pBz9VVFF/Bo-B-Detection.png
1 year 2 months ago #333949 by PCW
Discovery is an option in the board name menu:
Then:
Next setup the card name and communication details:
This shows the additional stepgens, encoders and PWMgens after discovery
Using 7i96s_5abob. bin firmware on the 7I96S:
Moderators: PCW, jmelson
Time to create page: 1.254 seconds
