RS485 Spindle Control
- giaviv
15 Jul 2025 06:57 #331847
by giaviv
RS485 Spindle Control was created by giaviv
Hey,
I have a Mesa 7i95t board that to my understanding has support for RS485.
I want to connect my Delta MS300 VFD to LinuxCNC over RS485, and I think I have two options:
* I've got a USB RS485 dongle that I can connect to the PC and to the VFD on the other end
* I can connect the Mesa board's RS485 terminals to the VFD
Which one of these options are preferable? Are both these options correct, and are there any pros/cons to either?
Thanks!
Thanks!
- Thank you received: 1480
17 Jul 2025 16:56 #331945
Replied by Todd Zuercher on topic RS485 Spindle Control
Using the USB dongle is much simpler and uses supported drivers that are included with Linuxcnc.
Using the Mesa board for controlling an RS485 device is more involved. Someone please correct me if I'm wrong, but I thought that you would be required to a custom firmware that would then need a custom modified Linux driver that supports your specific RS485 device (each device implements Modbus control differently.) There is very little if any documented support for this using Mesa. I've only read a few threads where people were wanting to try this, but I don't think I've seen any posts declaring success, let alone instructions.
17 Jul 2025 17:29 #331946
Looks like there is more support for Mesa than I was aware of.
linuxcnc.org/docs/2.9/html/drivers/mesa_...us.html#_quick_start
But it still looks more complicated than using USB.
- Benb
- Thank you received: 61
18 Jul 2025 00:43 #331960
by Benb
Replied by Benb on topic RS485 Spindle Control
As Todd mentioned, using a USB/RS-485 interface is likely your best option.
Although the HAL component vfdb_vfd.comp was originally designed for the Delta B series VFD, it seems that the Modbus addresses and commands are also compatible with the Delta 300 series. Since you already have everything needed to run a test, please go ahead and share your results. Your findings could be incredibly valuable to others in the future. As you've probably noticed, many users ask questions but rarely follow up with their findings—your feedback will be helpful for others using similar VFD.
linuxcnc.org/docs/stable/html/man/man1/vfdb_vfd.1.html
Time to create page: 0.131 seconds
