Hal Config 5i24+7i52+8i20
- stegrg
- Thank you received: 3
21 Jul 2025 12:22 #332115
by stegrg
Hal Config 5i24+7i52+8i20 was created by stegrg
Hello,
I'm trying to find a simple HAL file to configure Hudson BLDC motors in qhi mode. I have them running in h mode and qh mode, but I can't seem to get it running in qhi mode. When I run it in qhi mode, the motor seems to spin only in h mode and doesn't switch to qi mode. Does anybody have a simplified HAL file test script similar to the ones used in the following link for qhi mode?
forum.linuxcnc.org/forum/39-pncconf/2721...ting-up-5i257i858i20
Regards,
Regards,
- Thank you received: 7490
21 Jul 2025 14:00 #332121
Replied by tommylight on topic Hal Config 5i24+7i52+8i20
Moved to "driver boards".
Time to create page: 0.070 seconds
