Simulating a hm2_eth driver (e.g. mesacard 7i76e)
  • pkludwig
  • pkludwig's Avatar Topic Author
  • New Member
  • New Member
24 Jul 2025 15:52 #332267 by pkludwig
Hi everybody,
i found some threats (e.g. Simulate a mesa 7i96 (solved)) where a component was written for mocking a 7i96e mesacard. Nevertheless i didn't found this component code published and as i'm using myself a 7i76e card i wrote a component on my own for mocking/simulating this driver.
My idea was to use the same .ini and .hal-files (and .tcl-files with some if statements -)) as on my real milling machine to keep the adaptions between simulation and real machine as low as possible.
In case it is interesting/helpful, i put the component-code on github.com/pkl42/linuxcnc_components_sim.git
Also not all available pins are included right now, i added a detailed list on the git repository.
I tried to write the component in a generic way, so it should be quite easy to add missing pins or even adapting a 7i95 or 7i96 card.
The following user(s) said Thank You: tommylight, COFHAL
25 Jul 2025 08:57 #332297 by andypugh
You could consider adding this to the Wiki too.
wiki.linuxcnc.org/cgi-bin/wiki.pl?ContributedComponents
Here is how to edit a wiki page:
wiki.linuxcnc.org/cgi-bin/wiki.pl?BasicSteps
FWIW the penguin is called "Chips" (though I don't recall if he capitalises his name)
  • pkludwig
  • New Member
  • New Member
03 Aug 2025 10:12 #332713 by pkludwig
thanks for the hint with the wiki! -). I just added this under "Misc stuff".
Moderators: PCW, jmelson
Time to create page: 0.352 seconds
