Connecting my 7i96s to the VFD
25 Jul 2025 10:43 #332299 by Gautham
Connecting my 7i96s to the VFD was created by Gautham
Hi Everyone,
I have never setup a CNC machine before, so while I found many other people's posts on similar topics helpful, I'm still not confident enough to try it myself without asking someone if I have it correct. I have a 7i96s board, and I can see that the TB2 PINs 22,23,24 are as follows.
22 - SPINDLE-
23 - SPINDLE OUT
24 - SPINDLE+
And the below image is my VFD's pinout
From this I gather the following
22 - SPINDLE- to COM
23 - SPINDLE OUT to AI1
24 - SPINDLE+ to +10v
Is this correct? I also wanted to know how to control the direction. Thank you for being so helpful.
Gautham
25 Jul 2025 11:58 #332303 by tommylight
Replied by tommylight on topic Connecting my 7i96s to the VFD
Yes, that is correct.
25 Jul 2025 15:51 #332310 by PCW
Replied by PCW on topic Connecting my 7i96s to the VFD
For direction, assuming S1 is FWD and S2 is REV:
S1 --> OUT4A
OUT4B --> COM
S2 --> OUT5A
OUT5B --> COM
29 Jul 2025 05:57 - 29 Jul 2025 06:01 #332506 by Gautham
Replied by Gautham on topic Connecting my 7i96s to the VFD
Thank you so much PCW and tommy
PCW would that mean I don't connect 22 - SPINDLE- to COM, instead connect OUT4B --> COM and OUT5B --> COM?
Last edit: 29 Jul 2025 06:01 by Gautham.
29 Jul 2025 13:21 #332520 by PCW
They all connect to the VFD COM pin
(Spindle-,Out4b,Out5B --> VFD COM)
31 Jul 2025 07:04 #332586 by Gautham
Unserstood, thank you
25 Aug 2025 10:15 #333893 by Gautham
So I got my spindle and VFD wired up as you mentioned but as I am new to LinuxCNC I don't know how to set up my LinuxCNC to run my spindle. I am using 7i96s_5abobd.bin firmware if that has any impact on this. Thank you for being so helpful.
25 Aug 2025 15:00 #333907 by PCW
You should be able to use pncconf to setup your spindle
The firmware does not affect the spindle setup as the analog
spindle setup would be the same regardless of firmware.
A possible exception would be if you used the breakout board
to generate the analog spindle control voltage, but this would
really only make sense if you needed two analog outputs.
26 Aug 2025 09:42 #333937 by Gautham
Ok thanks for the tip. I tried to setup the spindle via pncconf but it didn't run. I have a screenshot below of what I tried. In the TB1/TB2 tab I selected spindle PWM as you can see. Is this the wrong place to setup the spindle?
26 Aug 2025 14:22 #333950 by PCW
What do you have selected to enable the spindle?
Typically you need one output for single direction spindles
and two for reversible spindles.
On a 7I96S, in hal, these would normally connect to the isolated
outputs on TB3, which in turn need to be wired to appropriate
VFD control pins.
Moderators: PCW, jmelson
Time to create page: 0.143 seconds
