Mesaflash is not able to find 5i25
  • GDTH
  • GDTH's Avatar Topic Author
  • Senior Member
  • Senior Member
03 Aug 2025 13:54 #332721 by GDTH
Not entirely sure if this is the correct category of the forum for this question, but here goes:I've just done a completely fresh install of LinuxCNC and I'm running into a few issues — some related to EtherCAT, but also with
mesaflash
.I'm trying to use
mesaflash
with a 5i25 board. I installed it and ran the following command:
sudo mesaflash --device 5I25 --readhmid
But I get this error:
pci_boards_init can't open /dev/mem: Operation not permitted
No 5I25 board found
The 5i25 itself isn't broken — I’ve tested it on another PC and it works fine.When I run
lspci -v
, I can see the board:
02:00.0 DPIO module: Device 2718:5125 (rev 01)
        Subsystem: Device 2718:5125
        Flags: medium devsel, IRQ 255
        Memory at d1000000 (32-bit, non-prefetchable) [disabled] [size=64K]
It feels like something went wrong during the software installation. Has anyone seen this before or know what might be wrong?
03 Aug 2025 14:02 #332722 by PCW
Replied by PCW on topic Mesaflash is not able to find 5i25
is suspicious, Sometimes this is BIOS option related.
  • GDTH
  • Senior Member
  • Senior Member
03 Aug 2025 15:00 #332728 by GDTH
Replied by GDTH on topic Mesaflash is not able to find 5i25
I have a small HP ProDesk 400 G3 SFF. From your suggestion i have looked at both devices (same pc type) bios settings, as of now nothing sticks out yet.
03 Aug 2025 16:07 #332735 by PCW
Does LinuxCNC find the card?
03 Aug 2025 20:00 #332758 by andypugh
Replied by andypugh on topic Mesaflash is not able to find 5i25
does "sudo mesaflash" get any further?
04 Aug 2025 02:17 - 04 Aug 2025 02:17 #332781 by PCW
He did use sudo, I expect this is a BIOS issue, and it appears that the
hm2_pci driver works around this with this:
    // NOTE: this enables the board's BARs -- this fixes the Arty bug
    if (rtapi_pci_enable_device(dev)) {
        LL_PRINT("skipping AnyIO board at %s, failed to enable PCI device\n", rtapi_pci_name(dev));
        return failed_errno = -ENODEV;
But I don't see any equivalent code in mesaflash (nor do I know the equivalent
of rtapi_pci_enable_device with the PCI library that mesaflash uses, but I can take a look.)
Last edit: 04 Aug 2025 02:17 by PCW.
  • GDTH
  • Senior Member
  • Senior Member
04 Aug 2025 07:55 - 04 Aug 2025 07:56 #332798 by GDTH
I will dig more into tonight and see if i can find something from the bios. The only thing i can think of is that linuxcnc was installed with secure boot.
Properply end up doing a fresh start with linuxcnc.
I will update on this, if i find something.
Last edit: 04 Aug 2025 07:56 by GDTH.
04 Aug 2025 08:05 #332800 by unknown
Replied by unknown on topic Mesaflash is not able to find 5i25
This seems to be an issue that seems to happen with HP boxes, add in cards seem to be disabled. This is just not related to Linuxcnc cards. Users have had issues with PCIe LPT cards and a month or so ago when doing a google search related to this it pops up in HP forums with no resolution (not just the above mentioned add in cards). (sorry I didn't bookmark the threads I found)
  • GDTH
  • Senior Member
  • Senior Member
08 Aug 2025 13:39 #333046 by GDTH
Okay, so I still don’t know exactly what the issue was. I checked the BIOS and compared it with another PC, but nothing stood out. After a while, I decided to just reinstall LinuxCNC 2.9.4 — and this time, it worked.
It might be because I installed other software in a different order; this time, I set up EtherCAT and everything else right away. I also removed the annoying
raspi-firmware
package, which could have been the culprit as well.
Moderators: PCW, jmelson
Time to create page: 1.207 seconds
