- Thank you received: 5334
My MESA 7i95T wiring
1 year 1 month ago #335671
Replied by PCW on topic My MESA 7i95T wiring
You can use a fast encoder for a MPG but one disadvantage of this is that fast encoders do not
support 1X mode, so if you want 1 increment of motion per MPG click you need to use the MPG encoders
- alexandrap
- Topic Author
1 year 1 month ago - 1 year 1 month ago #335691
by alexandrap
Replied by alexandrap on topic My MESA 7i95T wiring
it means , that 1 click to MPG = 4 pulses for feed?
so what is the solution ? set 1/4 of the feed value ?
only use the input designated for MPG (foto - input A0,B0) ?
i am trying to understand the links
forum.linuxcnc.org/27-driver-boards/4034...g-encoder-count-by-4
www.plctalk.net/forums/threads/encoder-x1-x2-and-x4.140711/
linuxcnc.org/docs/html/man/man9/encoder.9.html#PARAMETERS
Last edit: 1 year 1 month ago by alexandrap.
- alexandrap
- Topic Author
1 year 4 weeks ago - 1 year 4 weeks ago #335714
by alexandrap
MPG wheel connection - fixed
MPG ENCODER INPUTS
Standard 7I95T firmware provides 4 quadrature MPG encoder inputs on isolated inputs 0 through 7.
Since the input threshold on isolated inputs is about 3V, its best to use sinking inputs (with the input common terminal tied to +5V) with TTL output level MPGs.
INPUT ENCODER
0 QUADA-0 MPG 0
1 QUADB-0
2 QUADA-1 MPG 1
3 QUADB-1
4 QUADA-2 MPG 2
5 QUADB-2
6 QUADA-3 MPG 3
7 QUADB-3
The problem for me is that the MPG hand wheel function for inputs IN 00-07 cannot be selected from the submenu in the PNCONFG menu.
I don't know how to manually edit HAL.
MPG ENCODER INPUTS
INPUT ENCODER
0 QUADA-0 MPG 0
1 QUADB-0
2 QUADA-1 MPG 1
3 QUADB-1
4 QUADA-2 MPG 2
5 QUADB-2
6 QUADA-3 MPG 3
7 QUADB-3
Last edit: 1 year 4 weeks ago by alexandrap.
- alexandrap
- Topic Author
1 year 3 weeks ago - 1 year 3 weeks ago #336194
by alexandrap
MPG - initial attempts
is used original connection of MPG wheel to Encoder 4, configuration only with PNCconfig and manual editing of one component in HAL file based on the solution in this post :
162.243.45.186/39-pncconf/51627-mpg-issue-on-mesa-7i77
net joint-select-a (b,c)
to
net axis-select-x (y,z)
I need to change the scale and maximum speed settings.
It's a shame that the MPG configuration error in PNCCONFG hasn't been fixed - it would be possible for beginners (like me) to configure MESA 7i95T (and others...) using only PNCCONFG without manual editing
to
Last edit: 1 year 3 weeks ago by alexandrap.
- alexandrap
- Topic Author
10 months 1 week ago #340361
by alexandrap
first steps
Time to create page: 0.153 seconds
