5i25t firmware screwup
- Cooped-Up
- Thank you received: 4
07 Oct 2025 10:27 #335991
by Cooped-Up
Replied by Cooped-Up on topic 5i25t firmware screwup
I have a new section in the error codes where it does say it can see the 7i84. So it must be my call-out for the pins are incorrect. I am referencing a project where the guy had his 84 wired to his 7i77 but I am using the 7i74 to communicate with the 7i84 and 7i73. Is the pin call-out different currently it is "HM2_5i25.0.7i84.0.2.output-10"
- Cooped-Up
07 Oct 2025 10:38 #335992
by Cooped-Up
Okay I remember there was a section in the CNC panel for tools and hal stuff so I poked around there and found the specific call-out I need to address the 7i84. I'm starting to get excited as I was able to make something actually happen finally. I controlled an output on the 84 for "coolant" now I just need to add all of the lines for my machine and wire everything. I will likely return with more issues but I will probably make a new topic mostly for tracking my progress.
Time to create page: 0.069 seconds
