Fanuc encoders
- mark-v-d
- Thank you received: 7
06 Oct 2025 22:13 #335956
by mark-v-d
Fanuc encoders was created by mark-v-d
I've recently bought a Harrison Alpha 330 with a broken computer. I am
going to convert this lathe to linuxcnc using my own motor drives.
Since this lathe was using a Fanuc controller and I could not find
sufficient information about the Fanuc encoder protocol, I decided to
try to reverse engineer the protocol. And it seems I have succeeded and
would like to share what I have learnt about the protocol, in case anyone
else wants to re-use their Fanuc encoders.
The motors present are beta1/3000 or A06B-0031-B077 (X-axis) and
beta2/3000 or A06B-0032-B077 (Z-axis)
First of all the code can be found in
github.com/mark-v-d/motor_control/tree/fanuc
Both the file software/xmc4400/src/encoder.cpp and
software/xmc4400/src/crc_lut.h should contain all
the information necessary.
/* Fanuc***********************************************************/
Datarate is 1024kb/s. Send a positive pulse on REQ (pin-5) of 7..9us
to get a response. The response is 4 frames of 1 start bit, 16 data
bits and 1 stop bit. After the 4th frame the CRC is transmitted,
without a preceding startbit. The way to capture it, is to change
the word length of the 4th frame to 16+1+5 bits.
1st status
0xe000 3-msb changes, reason unknown
0x0100 index seen
0x0005 always there so-far.
2nd 16-bit counter within revolution
3rd revolution counter
4th absolute
0x8000 Always set?
0x03fc Commutation angle? After index the same as 2nd>>4
5th 5-bit CRC
1st status
0x0100 index seen
4th absolute
0x8000 Always set?
5th 5-bit CRC
07 Oct 2025 12:21 #335997
Replied by andypugh on topic Fanuc encoders
Is this the serial protocol, or the 4-bit gray code?
I think that _some_ Fanuc serial protocols are supported by Hostmot2:
linuxcnc.org/docs/stable/html/man/man9/h...html#Fanuc%20encoder
- jmelson
- Thank you received: 126
07 Oct 2025 14:13 #336008
by jmelson
Jon
Replied by jmelson on topic Fanuc encoders
Mark's message gives the details of the serial protocol. I don't know why he had to duplicate the effort, I have already deciphered these encoders and have a protocol converter product. But, now, Fanuc has a "High speed" encoder line that is incompatible with the older ones.Is this the serial protocol, or the 4-bit gray code?
Jon
- mark-v-d
07 Oct 2025 15:07 #336014
by mark-v-d
Replied by mark-v-d on topic Fanuc encoders
It could very well be the same, but I'm not sure. This is for the beta and not the alpha series of Fanuc. Like I said, I could not find the details of the protocol anywhere, but that could also mean I did not look in the right place.
- mark-v-d
07 Oct 2025 16:15 #336024
by mark-v-d
I've verified the vhdl and c code, and hostmot2 is indeed dealing with
the same protocol.
But at least now you know how to interpret the CRC, because that is not
done in hostmot2.
And I have learned where the batt_fail bit is (not that there is one on
the incremental encoder) They also don't seem to know what the purpose of
those 3 changing bits is. Maybe I'll figure that one out eventually.
the same protocol.
done in hostmot2.
- jmelson
07 Oct 2025 16:33 #336027
by jmelson
Your description looks JUST like what I deciphered.
One note, There are absolute and incremental versions of these encoders, at least on the older Alpha series. The absolute ones have extra data at the end that provides a 10-bit resolution absolute position immediately at power-on. The incremental encoders power-up assuming rotary position zero, and then the position count jumps when they pass the index position. So, you can't get any reliable commutation out of them without battery backup.
Jon
I never found any document on the data format, but I managed to insert a pulse and get the encoder to send data. Then, I looked at it on a scope, and created an FPGA to read the data and send it to a computer via the parallel port. I then spun the encoder by hand and wrote programs to extract the data. The hardest thing to crack was the CRC. I took some of the extracted data, and ran it through a program that tried many different CRC polynomials until I got a zero result from every data pattern. Then, I coded that up in VHDL and put it into my converter product.It could very well be the same, but I'm not sure. This is for the beta and not the alpha series of Fanuc. Like I said, I could not find the details of the protocol anywhere, but that could also mean I did not look in the right place.
Jon
- mark-v-d
07 Oct 2025 18:13 #336041
by mark-v-d
I have the incremental encoders in my lathe, they are the beta versions
however. On these encoders the 10-bit absolute position is there and
accurate enough to use for commutation right from the start. There is
a step in this data however once the encoder passes the index.
The control computer had a backup battery, the battery connection of
the encoders was not used. So I assume the computer was responsible
for remembering the position. There are no homing sensors on the lathe,
so I guess they ran the lathe to its endstops when the battery failed.
For me the hard part was to get the encoder to respond. It wants a
positive pulse on the REQ line, and initially I was trying a negative
pulse. After that, verifying the encoder position was simple enough with
a scope indeed.
The nice part about the CRC is that there are only 32 possible
polynomials, so bruteforcing works like a charm
I hope my information helps someone, but if not... nothing is lost.
I doubt reading the VHDL and C code of hostmot2 would have been faster
than what I did, but I certainly would have tried it, if had known about
it. On the other hand, the microcontroller I use can only capture frames
up to 64 bits, so knowing the padding are actually start and stop bits
was crucial.
a scope indeed.
was crucial.
The following user(s) said Thank You: vpomerleau
- jmelson
07 Oct 2025 20:32 #336053
by jmelson
On all the encoders, after power-on, there is a step in the high-res data when the encoder passes the index position. But, there is NO step in the low-res absolute data. My converter board FPGA makes the high-res step disappear as it converts to quadrature. I know WHY Fanuc went with the serial scheme, the quadrature count rates become insane when you start thinking about 1 million counts/rev, and so converting those to quadrature is not practical at full resolution.
Jon
Jon
- qiwating
27 Nov 2025 01:45 #339279
by qiwating
Replied by qiwating on topic Fanuc encoders
for Fanuc Encoders you can check here panasonicservomotor.com/fanuc-encoder. include code Fanuc code list
- jmelson
27 Nov 2025 16:36 #339335
by jmelson
That is just a list of error codes produced by the Fanuc control. I have a working converter for the 4-wire, low speed (1.024 mbit/second) encoders. I am now trying to decipher the 2-wire, 2.73 mbit/sec encoders. I have been able to trick an encoder to start responding by flipping switches on a pulse generator. But, I tried to set up an FPGA to get the encoder to respond, and I get NOTHING!
So, these encoders apparently need a different command to select the mode before it will respond.
Jon
Jon
Time to create page: 0.224 seconds
