Mesa 7i96S Daughter Card Question ... Can I use the 7i76U?
  • MusicCityMfg
  • MusicCityMfg's Avatar Topic Author
  • New Member
  • New Member
03 Nov 2025 13:06 #337754 by MusicCityMfg
I read the  Which Mesa Card Should I Buy?  post and it was super helpful.
I wanted to buy a Mesa 7i76EU card today but they are out of stock. They are also out of stock on the 7i77 daughter card.
So, I hope to buy a  7i96S today, but I need to know what daughter board I can use to increase the number of inputs an outputs?
Can I use the  7i76U ?
I am doing a manual lathe CNC conversion. I'm eventually going to be adding a 12 tool ATC turret.
I have not finalized all the required I/O yet, so I wanna make sure that I have enough I/O for future updates to the lathe.
If I can use the  7i76U , I think I will have plenty of I/O for future updates, that may include​ ...
  • a third MPG
  • an encoder on the ATC turret for tool location/identification,
  • a "Y" axis, three motor, four gang live tool option with an MPG (this last addition is way in the future if at all).
Thanks,
Chris​​​​​​
03 Nov 2025 14:20 - 03 Nov 2025 14:21 #337756 by tommylight
Mesa 7i84 has 32 inputs and 16 outputs, it easily wires to 7i96S with a cut down LAN/network cable, CAT5 or CAT6 will do just fine.
Did you try
store.mesanet.com
and
www.mesaus.com
mesaus.com/product/7i96s/
has 29 in stock.
Last edit: 03 Nov 2025 14:21 by tommylight. Reason: more info
The following user(s) said Thank You: MusicCityMfg
03 Nov 2025 15:06 #337757 by PCW
Yes, you can use a 7I76U with  a 7I96S  by using 7i96s_7i76d.bin firmware
and connecting the 7I76U to the 7I96S's P1 expansion connector.
  • MusicCityMfg
  • New Member
  • New Member
03 Nov 2025 17:17 - 03 Nov 2025 17:18 #337768 by MusicCityMfg
Thanks for your responses! I ordered the 7i96S and the 7i84U.
Probably overkill in terms of the amount of I/O, but now I can go hog wild with panel buttons (just kidding).
Now onto picking components for the CNC lathe conversion!
Last edit: 03 Nov 2025 17:18 by MusicCityMfg.
Moderators: PCW, jmelson
