Can I use these little 3d printer drivers with 7i96?
11 months 3 weeks ago #337978 by AgentWD40
TL;DR: Can I wire these little TMC2226 (or similar) 3d printer stepper drivers to a 7i96?
Before you laugh I know it seems like a silly matchup. I've been out of the cnc game for a few years now but now I have some projects on mind some I'm trying to plan to reuse some old parts. I'm still fairly out of the loop on the advances made in linuxcnc and hardware since.
I want to build another one of these light weight "3d printed" cncs . By default these machines used arduino/grbl based controllers , but I enjoy linuxcnc so I fully intend on on using linuxcnc instead.
I have a NIB Mesa 7i96 that I never put into production image missing /media/kunena/emoticons/sick.png.  I have some raspberry pi 4 Bs laying around from old projects. I would need to find new stepper drivers. These tiny stepper drivers are proven to work fine for these machines. I like the idea of cost and especially space savings with these little chips, and how the original design of the above linked machine integrates their electronics into the gantry.
So can I just wire these TMC2226s into the 7i96 as a drop in replacement for something  like my old TB6600 s?
I don't quite understand yet if these little chips with all their pins, and uart mode, are a different animal than the old stepper drivers I used before.
PS. I'm excited to find out that there is an official release for the rpi. I've already flashed it and have been poking around in it.
11 months 3 weeks ago - 11 months 3 weeks ago #337984 by tommylight
I forgot, do they have step/dir inputs?
If yes, then yes, they can be used with Mesa or parallel port.
Also, mind the power requirements as they do require 5V and 12-24V (or more).
Edit:
Just checked and yes they do have step/dir pins, so yes they will work.
Last edit: 11 months 3 weeks ago by tommylight. Reason: more info
The following user(s) said Thank You: AgentWD40
11 months 3 weeks ago #337987 by AgentWD40
Thank you, sir!
While I've got your attention I have another burning question, though slightly off topic.
As I mentioned I've been out of the loop for several years now. When I was last here plasmac (pre qtplasmac) was in heavy development and rpi4 support was "expiremental" and plasmac a no go.
Is the rpi a viable option now for a plasma table?
11 months 3 weeks ago #337994 by tommylight
Yes it is.
Personally, i will still not use RPI for sure, until it gets to under 50$, and since that will never happen, neither will my use of them.
I just buy old Lenovo laptops at 100-200 Euro a piece, and they come with everything included, battery and touchscreen included, all 14" of it. And it has much more processing power. With 2 cores.
11 months 3 weeks ago #337995 by AgentWD40
Out of curiosity what model and specs do you look for in your Lenovos? How often to you come across one that's just not suitable?
11 months 3 weeks ago #337996 by tommylight
Moderators: PCW, jmelson
Time to create page: 0.348 seconds
