connecting 7i96s to 2-wire RS485 using Pktuart
- cajbr
- Thank you received: 3
12 Nov 2025 17:58 #338267
by cajbr
connecting 7i96s to 2-wire RS485 using Pktuart was created by cajbr
I have a 7i96s rev E that I'm trying to connect to a WJ200 VFD. The VFD uses a 2-wire RS485 interface with pins labeled SN and SP.
How should I connect this to the 7i96s i/o pins? What position should W7 be in?
Thanks,
BR
Thanks,
BR
- Thank you received: 5334
12 Nov 2025 18:16 #338268
Replied by PCW on topic connecting 7i96s to 2-wire RS485 using Pktuart
This is described on page 11 of the 7I96S manual
basically:
RX-/TX- connect to RS-485 "A"
RX+/TX+ connect to RS-485 "B"
W7 right
basically:
W7 right
Time to create page: 0.094 seconds
