Hardware & Machines
Driver Boards
LinuxCNC Hardware Survey
Poll: LinuxCNC Hardware Survey (was ended 2025-12-20 00:00:00)
Mesa (all types) |
45 |
64.3%
Pico (all types) |
4 |
5.7%
General Mechatronics |
No votes |
0%
Motenc |
No votes |
0%
Servo-to-Go |
1 |
1.4%
PCL720 |
No votes |
0%
Pluto |
No votes |
0%
Vigilant Technologies ENCDAC |
No votes |
0%
TIRO (PC104) |
No votes |
0%
Siemens Evoreg |
No votes |
0%
Axiom AX5241H |
No votes |
0%
Parallel Port |
8 |
11.4%
EtherCAT |
12 |
17.1%
Total number of voters: 70 |
Only registered users can participate to this poll
andypugh
Away
Moderator
Thank you received: 4656
20 Nov 2025 17:18 - 22 Nov 2025 16:39 #338840
LinuxCNC supports a wide range of hardware, including a number of obsolete ISA cards etc.
In order to prioritise maintenance of the drivers (and possibly to retire some drivers) it would be useful to know what hardware is out there "in the wild"
Please fill out the survey below selecting any hardware that you use yourself, or have recently seen in use.
(Edit) The poll only appears to allow a single selection, but I have enabled multiple votes per user, so it may be possible to add data for several hardware devices.
Last edit: 22 Nov 2025 16:39 by andypugh.
The following user(s) said Thank You: travis036
Thank you received: 37
andypugh
Away
Moderator
Thank you received: 98
23 Nov 2025 12:13 #339070
by zz912
Egerobotics components are based on EtherCAT. Is it possible to add such components to the LinuxCNC distribution? I know there are some licensing issues with EtherCAT. Or not?
rodw
Away
Platinum Member
Thank you received: 4155
23 Nov 2025 13:23 #339078
Licencing Conditions pervents us from hosting ethercat stuff. The correct course of action ewould be to create pull requests against this rep,
github.com/linuxcnc-ethercat
the Ethercat master is configured as a dependency
The driver and devices here are synced to the iGh ethercat apt repository so that ethercat users can receive updated linuxcnc specific ethercat drivers with a simple apt upgrade
24 Nov 2025 20:59 #339182
by emresensoy
We have ESI files and many examples,
But, of course a driver is better than ever
tommylight
Away
Moderator
Thank you received: 7504
25 Nov 2025 15:45 #339222
Add another vote for me for the parallel port, i still use it a lot.
I did vote for Mesa, the absolute reason being reliability, for both Mesa and Parallel port.
andypugh
Away
Moderator
26 Nov 2025 15:32 #339269
Mesa, Pico, Parallel port and EtherCAT are safe.
It's the other stuff I am really interested in. Can we safely sunset those drivers?
Thank you received: 126
26 Nov 2025 16:44 #339272
by jmelson
Servo2Go seems to still exist, but I don't see anything like the original Servo2Go ISA bus interface card on their web page.
Jon
andypugh
Away
Moderator
26 Nov 2025 16:58 #339275
I am not sure if servo2go is the same as servotogo.
The servotogo.com address now seems to redirect to an Indonesian lottery site.
Hardware & Machines
Driver Boards
Time to create page: 0.499 seconds
