SmartSerial on cheap ESP32-8ch-Relais Card
11 months 1 week ago - 11 months 1 week ago #339183 by meister
i modified the  mesa-smartserial-device-template a little bit
and put it on a cheap ESP32 8ch-Relay board for extra Outputs.
i used platformio as buildsystem for easy use, i have also test the code on raspberry-pico,
github.com/multigcs/SmartSerial-ESP32RelayX8Board/tree/main
www.youtube.com/shorts/6ZKBH5xW8OQ
Relay-Board: www.amazon.de/dp/B0FNRH8QSN
Optional: www.amazon.de/TECNOIOT-Two-Way-Transfer-...tional/dp/B081J5R35N
Works fine with 7i92, but have still problems with 7c81 SmartSerial connector, not shure why,
maybe my pinout is wrong or problems with the TX_en stuff.
my Board with RS422 mod:
Last edit: 11 months 1 week ago by meister.
The following user(s) said Thank You: unknown
11 months 1 week ago #339214 by meister
ok, works also on the 7c81 ports :)
11 months 1 week ago #339221 by tommylight
Small soldered board, is it the RS422 to RS232 converter, or just a line driver?
Nice work, i do like the ESP32 due to it's versatility.
Thank you.
11 months 1 week ago - 11 months 1 week ago #339223 by meister
the small one is an RS422 to TTL
little update:
youtube.com/shorts/vfd948wLu4w
10 months 4 weeks ago - 10 months 1 week ago #339684 by HaroldHarvey
Essas placas ESP32 baratas funcionam, mas exigem mais testes do que soluções industriais. A fase experimental faz lembrar os primeiros passos dos casinos em portugal no ambiente digital. Testar, errar e ajustar faz parte do processo.
Last edit: 10 months 1 week ago by HaroldHarvey.
7 months 1 week ago #344656 by feng
Hello, I'm trying to clone this board. Do you have any HAL file references?
Moderators: PCW, jmelson
Time to create page: 0.165 seconds
