C axis with a VFD?
- matasbuk
- Thank you received: 3
09 Dec 2025 21:14 #339926
by matasbuk
C axis with a VFD? was created by matasbuk
Hello,
I am retrofitting a lathe and replacing the original 30kw Baumuller servo spindle with a 7.5kw three phase motor. The main reason is the controller is dead and repair is not worth it for me money wise. The lathe has a C axis with hydraulic disc brake. I do not need an active C axis, just orienting and locking in place is enough for me. Would this be possible to achieve accurately with the VFD? If so, have anyone perhaps tried it and could give reccomendations for the VFD and motor parameters? How many poles, etc. I need max 6000RPM from the motor, the spindle has a 1:2 belt reduction.
- Thank you received: 5335
09 Dec 2025 22:24 #339930
Replied by PCW on topic C axis with a VFD?
A VFD is normally not a very good servo system because it has such limited control bandwidth.
It may be workable if orientation is run very slowly, you have a good spindle encoder and do not expect
perfection in the orient angle.
The following user(s) said Thank You: matasbuk
- matasbuk
10 Dec 2025 21:30 - 11 Dec 2025 18:45 #339955
by matasbuk
Replied by matasbuk on topic C axis with a VFD?
Thank you for the reply. Will try to get something to work.
Thinking about using Delta C2000 VFD.
Last edit: 11 Dec 2025 18:45 by matasbuk.
Time to create page: 0.425 seconds
