6i25 and 7i77 config
- cdamm11
- Thank you received: 3
13 Dec 2025 11:51 #340043
by cdamm11
6i25 and 7i77 config was created by cdamm11
Hello LinuxCNC experts!
I am having a hard time setting up my LinuxCNC configuration. I have a 6i25 and 7i77. I have confirmed 5V to the P1 connector and jumper is in right hand. I have 26V on TB2. All others connector i have removed from the 7i77.
I have installed: linuxcnc_2.9.4 amd64.hybrid iso file. My Jitter is good.
I did not buy the 6i25 and 7i77 as a kit. i tried to load the firmware this way;
sudo mesaflash --device 5i25 --write (my directory)/5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
i used the files from mesa website. And it seems to flash without problems.
Than i tried to use pnconf. i setup the encoders XYZ and PWM XYZ and the correct scaling.
When i load the program my pc just reboots. I get no errors. I tried to alot of things from these forums but i cant get any sucess.
Best regards Christian
- Thank you received: 7498
13 Dec 2025 12:04 #340045
Replied by tommylight on topic 6i25 and 7i77 config
That is most certainly a PC issue, not Mesa/LinuxCNC issue, so the first thing to try is insert the 6i25 into another PCI-E slot, even the long 16X one will work, and so will 8X and 4X ones.When i load the program my pc just reboots.
- cdamm11
13 Dec 2025 12:38 #340046
by cdamm11
Replied by cdamm11 on topic 6i25 and 7i77 config
Hi Tommy!
The PC only has 1 PCIE X16 so that is problematic
I can see this in terminal:
mesaflash --device --5i25
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn5 (Out)
14 18 IOPort SSerial 0 TXData5 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData4 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData3 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
is there anything else i can test in software / firmware / drivers?
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 3
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
13 Dec 2025 14:40 #340051
No, not really, you will need another PC at least.
Lets clear something up first, does the PC reboot when turning ON the Mesa cards, or, when running LinuxCNC ?
- cdamm11
13 Dec 2025 15:08 #340053
by cdamm11
the pc only reboots when i try to run my configuration. i can run Sample configurations like "axis". But when i try to run the config i created using pncconf wizard the pc just reboots. i also does this if i try to Open Loop test or test / tune axis.
13 Dec 2025 15:18 #340054
Find or borrow a used PC.
- NWE
- Thank you received: 84
13 Dec 2025 15:22 #340055
by NWE
Replied by NWE on topic 6i25 and 7i77 config
Does the pc have a metal housing (shielded), with the 6i25 inside? Or is it a motherboard mounted in a cabinet that also contains a VFD, relays, etc? If so, your motherboard will likely need additional shielding.
- cdamm11
13 Dec 2025 16:27 #340058
by cdamm11
Yes the PC is in metal housing and right now it is outside the control cabinet. I am confident this is not a EMC issue.
i have bought a much older pc which i will test tommorow.
thanks so far.
thanks so far.
The following user(s) said Thank You: tommylight, NWE
- cdamm11
19 Jan 2026 08:55 #341569
by cdamm11
Just to end this topic: i bought a new PC and LCNC booted up. So the issue was proberly that i used a too new PC with buggy/Incompabtible PCI-E.
The following user(s) said Thank You: NWE
Time to create page: 0.094 seconds
