- Hardware & Machines
- Driver Boards
- Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
- Ozcnc
29 Dec 2025 06:18 #340649
by Ozcnc
Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2 was created by Ozcnc
Hello,
I've spent a few days getting Linuxcnc 2.9.7 up and running with a Mesa 5i25 board, properly flashed and functioning.
My hardware setup consists of 2no X-axis gecko 203V drives, 1no Y - axis, 1no Z-axis, and 1no A-axis.
I have x,y,z home switches, e-stop, and Highspeed Spindle.
I have been trying to get the mesa card to work with a HKD 5 AXIS MACH3 BOB.
Currently i can get mesa to drive the gecko drives and motors if I connect directly (Testing Purposes Only).
I cannot get the HKD BOB to drive the gecko drives and motors.
Does anyone have suggestions?
Thanks,
Orrin
Thanks,
Orrin
- Thank you received: 5336
29 Dec 2025 10:20 #340664
Replied by PCW on topic Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
Do you have a link to the manual for the HKD breakout?
Also make sure you do not have cable power enabled on the 5I25.
- Ozcnc
29 Dec 2025 12:48 #340670
by Ozcnc
Replied by Ozcnc on topic Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
Here is the files that were posted for it.
The following user(s) said Thank You: NWE
- Ozcnc
29 Dec 2025 12:50 #340671
by Ozcnc
- Ozcnc
29 Dec 2025 13:04 #340672
by Ozcnc
Breakout power option is off.
29 Dec 2025 14:17 #340675
Did you verify that the BOB has 5V power?
It needs both 5 and 12V power for operation,
5V for the step/dir outputs and 12V for the analog out and digital inputs
- Ozcnc
29 Dec 2025 22:15 #340696
by Ozcnc
Bob has 5v using usb.
I'm only working with 5v now to get step/dir outputs working.
I will connect the 12v supply to run the spindle.
- Ozcnc
31 Dec 2025 02:29 #340759
by Ozcnc
I've ordered a MESA 7i76U, should get the machine up and running once configured.
I'm going to park this one.
- Driver Boards
Time to create page: 0.098 seconds
