7i92M + 7i76 add PWM+PktUART
- SOLD
- Thank you received: 13
07 Jan 2026 00:54 - 07 Jan 2026 01:17 #341114
by SOLD
7i92M + 7i76 add PWM+PktUART was created by SOLD
Hello PCW,I am using a Mesa 7i96M with a 7i76, and I would like to ask a question regarding firmware configuration before requesting any custom bitfile.Question:
Is it possible for PktUART to be used instead of SSerial in a 7i96M firmware configuration?
I would like to understand whether PktUART can be implemented in place of SSerial, or if SSerial is architecturally fixed and not interchangeable.If this is feasible, I would like to request a custom bitfile with the following changes:
- Replace SSerial with PktUART
- Repurpose STEP5 (unused in my system) as a PWM output
- Keep all other functions the same as the standard 7i96M + 7i76 firmware
Last edit: 07 Jan 2026 01:17 by SOLD.
- Thank you received: 5336
07 Jan 2026 10:01 #341133
Replied by PCW on topic 7i92M + 7i76 add PWM+PktUART
Unfortunately the serial interface on the 7I76 is RS-422 only so not suitable for Modbus
which normally requires a 2 wire (RS-485) connection.
You could add a single chip RS-485 adapter to the second 7I92 connector though.
Perhaps using a SP491 with the proper RS-485 bias resistors
The following user(s) said Thank You: SOLD
- SOLD
08 Jan 2026 04:24 #341166
by SOLD
Replied by SOLD on topic 7i92M + 7i76 add PWM+PktUART
Thank you for your previous reply and guidance regarding the RS-422 interface
on the 7i76 and the suggestion to use an external RS-485 transceiver.
That explanation was very helpful.
I am currently using the 7i92_7i76x2d_2pwm bitfile, and I have reviewed the
IDROM configuration using mesaflash.
From the IDROM, StepGen 5, 6, and 7 are mapped to P1 DB25 pins
1/14, 2/15, and 3/16. These step generators are unused in my system.
I would like to ask whether it would be possible to replace StepGen 5–7
with two additional QCount modules (Quad-A, Quad-B, and Quad-IDX),
using those same I/O pins.
If this is feasible and acceptable from a resource standpoint,
would you be willing to provide a custom bitfile with this change?
Thank you again for your time and for your continued support.
08 Jan 2026 14:50 #341175
That's possible, I'll take a look when I get a chance
09 Jan 2026 10:40 #341209
- SOLD
12 Jan 2026 23:36 #341340
by SOLD
Thank you very much for the quick turnaround and for providing the custom bitfile.
I have successfully flashed it and will begin testing shortly.
I really appreciate your help and support.
- SOLD
28 Jan 2026 06:47 - 28 Jan 2026 06:49 #342079
by SOLD
Hello PCW,
I would like to ask for guidance regarding a firmware issue with a Mesa 7i92 + 7i76 system, and clarify the exact sequence of events.
LinuxCNC reported the following warning:
hm2/hm2_7i92.0: Warning: sserial remote device 7i76 channel 0 has old firmware that should be updated
Based on this warning, I attempted to update the Smart-Serial firmware.
At that time, I assumed that 7I76U.BIN could be used as a compatible replacement and used it to update the 7i76. This was a deliberate decision made in response to the hm2 warning, not an accidental flash.
After this, the system no longer behaves as expected.
Current status:
7i92 Ethernet communication works normally.
The Smart-Serial port responds and reports SSLBP version, channel count, and baud rate.
I reflashed with 7i92_7i76x1D.bit, followed by a full power cycle.
The W3 jumper on the 7i76 has been changed as recommended.
Attempting to rewrite 7I76R14.BIN via mesaflash produces no errors, however there is no explicit indication that a firmware rewrite actually occurred, and the observable behavior of the board does not change.
Is there any supported recovery method for a 7i76 in this condition, assuming access to a working Smart-Serial master (7i92)?
Current status:
cnc@cnc:~/Desktop/UP FW7i77/sserial/utils/linuxcnc$ cd "/home/cnc/Desktop/UP FW7i77/sserial/utils/linuxcnc"
halrun -f update7i76u-eth.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:13:05:8a
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Low Level init 0.15
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: num_channels = 4
hm2/hm2_7i92.0: Chan 0 baudrate = 2500000
hm2/hm2_7i92.0: Chan 0. Baudrate set to 115200
hm2/hm2_7i92.0: Chan 1 baudrate = 2500000
hm2/hm2_7i92.0: Chan 1. Baudrate set to 115200
hm2/hm2_7i92.0: Chan 2 baudrate = 2500000
hm2/hm2_7i92.0: Chan 2. Baudrate set to 115200
hm2/hm2_7i92.0: Chan 3 baudrate = 2500000
hm2/hm2_7i92.0: Chan 3. Baudrate set to 115200
Setup mode
found a 7I76
Setup mode
Looking for 8i20s, crc_addr = 192
found a
Setup mode
Looking for 8i20s, crc_addr = 242
found a
Setup mode
Looking for 8i20s, crc_addr = 292
found a
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 001 (P2-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 004 (P2-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 008 (P2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): Smart Serial Interface #0, pin tx1 (Output)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): Smart Serial Interface #0, pin rx1 (Input)
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Encoder #0, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Encoder #0, pin B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Encoder #0, pin A (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): StepGen #5, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 018 (P1-14): StepGen #5, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #6, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): StepGen #6, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #7, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #7, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): PWMGen #0, pin Out1 (Dir or Down) (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 025 (P1-05): PWMGen #1, pin Out1 (Dir or Down) (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): Smart Serial Interface #0, pin tx2 (Output)
hm2/hm2_7i92.0: IO Pin 028 (P1-08): Smart Serial Interface #0, pin rx2 (Input)
hm2/hm2_7i92.0: IO Pin 029 (P1-09): Smart Serial Interface #0, pin tx3 (Output)
hm2/hm2_7i92.0: IO Pin 030 (P1-10): Smart Serial Interface #0, pin rx3 (Input)
hm2/hm2_7i92.0: IO Pin 031 (P1-11): Encoder #1, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 032 (P1-12): Encoder #1, pin B (Input)
hm2/hm2_7i92.0: IO Pin 033 (P1-13): Encoder #1, pin A (Input)
hm2/hm2_7i92.0: registered
flash command
Firmware size 0x953c
setup start: data_reg readback = 0
hm2/hm2_7i92.0: Write Size = 100, Erase Size = 800
hm2/hm2_7i92.0: Skipped Block 1
hm2/hm2_7i92.0: Skipped Block 2
hm2/hm2_7i92.0: Skipped Block 3
hm2/hm2_7i92.0: Skipped Block 4
hm2/hm2_7i92.0: Skipped Block 5
hm2/hm2_7i92.0: Skipped Block 6
hm2/hm2_7i92.0: Skipped Block 7
hm2/hm2_7i92.0: Erased block 8
hm2/hm2_7i92.0: Wrote block 8
hm2/hm2_7i92.0: Skipped Block 9
hm2/hm2_7i92.0: Erased block 10
hm2/hm2_7i92.0: Wrote block 10
hm2/hm2_7i92.0: Erased block 11
hm2/hm2_7i92.0: Wrote block 11
hm2/hm2_7i92.0: Erased block 12
hm2/hm2_7i92.0: Wrote block 12
hm2/hm2_7i92.0: Erased block 13
hm2/hm2_7i92.0: Wrote block 13
hm2/hm2_7i92.0: Erased block 14
hm2/hm2_7i92.0: Wrote block 14
hm2/hm2_7i92.0: Erased block 15
hm2/hm2_7i92.0: Wrote block 15
Error flag set after CMD Clear 00000001
hm2/hm2_7i92.0: Error in sslbp_write_byte, trying to abort
hm2/hm2_7i92.0: Error in sslbp_read_cookie, trying to abort
hm2/hm2_7i92.0: Synch failed during block erase: aborting
Firmware Flash Failed
setsserial: rtapi_app_main: Operation not permitted (-1)
setsserial: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
<commandline>:0: unloadrt failed
Last edit: 28 Jan 2026 06:49 by SOLD.
28 Jan 2026 09:28 #342081
Unfortunately the 7I76U uses a complete different processor
with different firmware memory layout so I expect the only way
to recover is with a (newer) PIC programmer.
- SOLD
28 Jan 2026 21:40 #342137
by SOLD
Is restoring a 7i76 by externally reprogramming the dsPIC with the proper 7I76R14 image theoretically possible
If recovery requires a Mesa-provided programming image or process, is there any form of guidance or support you can offer? I fully understand if this is not something Mesa can support or disclose.
29 Jan 2026 11:13 - 29 Jan 2026 11:16 #342160
The 7I76R14.BIN image will not work as there are two program images
in the DSPIC code (the setup and working images) This is done to allow
live updates.
This is the complete 7I76 image:
live updates.
Last edit: 29 Jan 2026 11:16 by PCW.
Time to create page: 0.254 seconds
