Thanks for the feedback! You’ve raised some classic points about LinuxCNC architecture. Let me clarify my design choices:
1. Why Arduino UNO & Serial Converter? You’re right, native USB (like 32u4) is faster, but the UNO is the most ubiquitous board on the planet. I chose it for the Evaluation to make it accessible to everyone. My dedicated hardware is optimized for the task. Regarding CDC, the driver handles the communication stream to ensure packet integrity without the overhead of complex generic protocols.
2. Closed Firmware & 'Over-engineering' I respect the Open Source philosophy, but io_decoder is a professional project that includes dedicated hardware. The 'over-engineering' you see in the HAL driver is actually optimization. While a user-space component can work, a dedicated C component ensures deterministic polling and much lower jitter. If you want a 'professional feel' on the handwheel, those milliseconds matter.
3. USB Stability & Real-Time Thread I’m well aware that USB isn't for the Servo Thread. In fact, io_decoder doesn't try to be a motion controller. It’s an HMI driver. The reason it’s written as a component is to ensure that the communication window is synchronized and doesn't suffer from the unpredictable latencies of user-space scheduling.Regarding errors: the driver includes a specific state-machine to handle reconnections much faster than a standard generic serial bridge.
4. The Goal Most 'standard' serial-to-HAL projects are hacks. io_decoder is a finished product. It’s for the user who wants to plug in a board, load a component, and have a 100% reliable, low-latency control panel without writing a single line of Python or C.I invite you to actually test the Eval version.
You’ll see that the 'over-engineering' results in a responsiveness that user-space scripts simply can't match.
