Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
9 months 3 days ago - 9 months 3 days ago #342113 by COFHAL
I use Arduino Connector, I really like your project, it's very professional. I don't know if you plan to create matrix-type keyboards to simulate keys or to be used as HAL pins like in Arduino Connector, which gives great flexibility.
Last edit: 9 months 3 days ago by COFHAL.
The following user(s) said Thank You: meister, bobwolf, NWE
9 months 3 days ago - 9 months 3 days ago #342121 by unknown
So.....you are wanting testers for a closed source hardware project ;)
What's in it for the testers ? :)
USB Stability & Real-Time Thread I’m well aware that USB isn't for the Servo Thread.
What thread will it run in ? And you suggesting another thread to add to a config ? What period would this be run at ?
How would that affect a config that has a base thread (for software step gen) and a servo thread for other functions ?
Last edit: 9 months 3 days ago by unknown.
The following user(s) said Thank You: bobwolf
9 months 3 days ago #342150 by meister
2. Closed Firmware & 'Over-engineering' I respect the Open Source philosophy, but io_decoder is a professional project that includes dedicated hardware. The 'over-engineering' you see in the HAL driver is actually optimization. While a user-space component can work, a dedicated C component ensures deterministic polling and much lower jitter. If you want a 'professional feel' on the handwheel, those milliseconds matter.
ahh, ok, This is what professional code looks like when compiling.
halcompile --compile io_decoder.c Compiling realtime io_decoder.c io_decoder.c: In function ‘usb_thread_function’: io_decoder.c:1119:60: warning: comparison of integer expressions of different signedness: ‘int’ and ‘long unsigned int’ [-Wsign-compare] 1119 | if (tx_buffer_size > sizeof(io->tx_packet_buffer)) { | ^ io_decoder.c:1214:80: warning: comparison of integer expressions of different signedness: ‘int’ and ‘uint32_t’ {aka ‘unsigned int’} [-Wsign-compare] 1214 | if (parsed_len == io->usb_rx_payload_len) { // | ^~ io_decoder.c:1318:31: warning: variable ‘rx_success_delta’ set but not used [-Wunused-but-set-variable] 1318 | float rx_success_delta = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:1316:31: warning: variable ‘tx_success_delta’ set but not used [-Wunused-but-set-variable] 1316 | float tx_success_delta = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:1313:31: warning: variable ‘rx_success’ set but not used [-Wunused-but-set-variable] 1313 | float rx_success = 0; | ^~~~~~~~~~ io_decoder.c:1311:31: warning: variable ‘tx_success’ set but not used [-Wunused-but-set-variable] 1311 | float tx_success = 0; | ^~~~~~~~~~ io_decoder.c:805:13: warning: unused variable ‘serial_verify’ [-Wunused-variable] 805 | int serial_verify; | ^~~~~~~~~~~~~ io_decoder.c:783:21: warning: unused variable ‘old_usb_loop’ [-Wunused-variable] 783 | static long old_usb_loop; | ^~~~~~~~~~~~ io_decoder.c:776:20: warning: unused variable ‘old_pin_debug2’ [-Wunused-variable] 776 | static int old_pin_debug2 = 0; | ^~~~~~~~~~~~~~ io_decoder.c:775:20: warning: unused variable ‘old_hand_invalid_received’ [-Wunused-variable] 775 | static int old_hand_invalid_received = 0; | ^~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:773:20: warning: unused variable ‘old_hand_invalid_send’ [-Wunused-variable] 773 | static int old_hand_invalid_send = 0; | ^~~~~~~~~~~~~~~~~~~~~ io_decoder.c:771:20: warning: unused variable ‘old_hand_valid_received’ [-Wunused-variable] 771 | static int old_hand_valid_received = 0; | ^~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:769:20: warning: unused variable ‘old_hand_valid_send’ [-Wunused-variable] 769 | static int old_hand_valid_send = 0; | ^~~~~~~~~~~~~~~~~~~ io_decoder.c:755:16: warning: variable ‘comm_packet_received_and_validated’ set but not used [-Wunused-but-set-variable] 755 | static int comm_packet_received_and_validated = 0; // Per controllare il loop all'interno di COMMUNICATING | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:754:16: warning: unused variable ‘comm_packet_sent’ [-Wunused-variable] 754 | static int comm_packet_sent = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:751:16: warning: variable ‘error_state_comm_timeout’ set but not used [-Wunused-but-set-variable] 751 | static int error_state_comm_timeout = 0; | ^~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:750:16: warning: variable ‘error_state_hand_serial_read’ set but not used [-Wunused-but-set-variable] 750 | static int error_state_hand_serial_read = 0;; // Per seriale in handshake errata | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:749:16: warning: variable ‘error_state_payload’ set but not used [-Wunused-but-set-variable] 749 | static int error_state_payload = 0; // Per payload in handshake errato | ^~~~~~~~~~~~~~~~~~~ io_decoder.c:748:16: warning: variable ‘error_state_firmware_2’ set but not used [-Wunused-but-set-variable] 748 | static int error_state_firmware_2 = 0; // Per valori funzioni dentro il firmware errate | ^~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:747:16: warning: variable ‘error_state_firmware’ set but not used [-Wunused-but-set-variable] 747 | static int error_state_firmware = 0; // Per firmware errato | ^~~~~~~~~~~~~~~~~~~~ io_decoder.c:746:16: warning: variable ‘error_state_hand_packet’ set but not used [-Wunused-but-set-variable] 746 | static int error_state_hand_packet = 0; // Per pacchetto di handshake di lunghezza non corrispondente | ^~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:745:16: warning: variable ‘error_state_serial_configure’ set but not used [-Wunused-but-set-variable] 745 | static int error_state_serial_configure = 0; // Per seriale non configurata | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:743:16: warning: unused variable ‘error_state_dbg_printed’ [-Wunused-variable] 743 | static int error_state_dbg_printed = 0; // Per HAL_STATE_ERROR (primo ingresso) | ^~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:740:16: warning: unused variable ‘handshake_response_dbg_printed’ [-Wunused-variable] 740 | static int handshake_response_dbg_printed = 0; // Per HAL_STATE_HANDSHAKE_WAIT_RESPONSE | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:739:16: warning: unused variable ‘handshake_init_dbg_printed’ [-Wunused-variable] 739 | static int handshake_init_dbg_printed = 0; // Per HAL_STATE_HANDSHAKE_INIT | ^~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:737:16: warning: unused variable ‘timer_overflow_5’ [-Wunused-variable] 737 | static int timer_overflow_5 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:735:16: warning: unused variable ‘timer_overflow_3’ [-Wunused-variable] 735 | static int timer_overflow_3 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:734:16: warning: unused variable ‘timer_overflow_2’ [-Wunused-variable] 734 | static int timer_overflow_2 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:733:16: warning: unused variable ‘timer_overflow_1’ [-Wunused-variable] 733 | static int timer_overflow_1 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:732:16: warning: unused variable ‘timer_overflow_0’ [-Wunused-variable] 732 | static int timer_overflow_0 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:724:17: warning: variable ‘last_read_time_ns’ set but not used [-Wunused-but-set-variable] 724 | static long last_read_time_ns; // Inizializza al tempo corrente | ^~~~~~~~~~~~~~~~~ io_decoder.c:720:10: warning: unused variable ‘next_handshake_attempt_time_ns’ [-Wunused-variable] 720 | long next_handshake_attempt_time_ns = 0; // Tempo per il prossimo tentativo di handshake | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c: In function ‘npic_in_routine’: io_decoder.c:1443:72: warning: unused parameter ‘length’ [-Wunused-parameter] 1443 | uint8_t npic_in_routine(hal_io_decoder_t *io, uint8_t* buffer, uint8_t length) { | ~~~~~~~~^~~~~~ io_decoder.c: In function ‘npic_out_routine’: io_decoder.c:1494:68: warning: unused parameter ‘length’ [-Wunused-parameter] 1494 | void npic_out_routine(hal_io_decoder_t *io, uint8_t* dato, uint8_t length) { | ~~~~~~~~^~~~~~ io_decoder.c: In function ‘encoder_routine’: io_decoder.c:1577:9: warning: unused variable ‘encoder_delta_from_arduino’ [-Wunused-variable] 1577 | int encoder_delta_from_arduino; // Questo sarà il valore decodificato (il "delta") | ^~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c: In function ‘adc_routine’: io_decoder.c:1770:57: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int32_t’ {aka ‘int’} [-Wsign-compare] 1770 | if ((io->adc_raw_joy[i] <= joy_center_plus) && (io->adc_raw_joy[i] >= joy_center_minus)) { | ^~ io_decoder.c:1770:100: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int32_t’ {aka ‘int’} [-Wsign-compare] 1770 | if ((io->adc_raw_joy[i] <= joy_center_plus) && (io->adc_raw_joy[i] >= joy_center_minus)) { | ^~ io_decoder.c:1778:48: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int32_t’ {aka ‘int’} [-Wsign-compare] 1778 | if (io->adc_raw_joy[i] > (joy_center_plus)) { | ^ io_decoder.c:1784:55: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int32_t’ {aka ‘int’} [-Wsign-compare] 1784 | } else if (io->adc_raw_joy[i] < (joy_center_minus)) { | ^ io_decoder.c:1680:17: warning: unused variable ‘joy_offset’ [-Wunused-variable] 1680 | int32_t joy_offset; | ^~~~~~~~~~ io_decoder.c:1678:10: warning: unused variable ‘overflow_period_ns’ [-Wunused-variable] 1678 | long overflow_period_ns = 20 * 1000 * 1000; // Periodo di 20ms per resettare l'overflow | ^~~~~~~~~~~~~~~~~~ io_decoder.c: In function ‘DAC_out_routine’: io_decoder.c:1874:13: warning: unused variable ‘i’ [-Wunused-variable] 1874 | int i; | ^ io_decoder.c: In function ‘in_expansion_routine’: io_decoder.c:1918:13: warning: unused variable ‘current_value’ [-Wunused-variable] 1918 | float_t current_value = 0; // Useremo un int32_t per gestire il valore | ^~~~~~~~~~~~~ io_decoder.c:1917:13: warning: unused variable ‘bytesWritten’ [-Wunused-variable] 1917 | uint8_t bytesWritten = 0; // Contatore dei byte letti dal buffer | ^~~~~~~~~~~~ io_decoder.c:1916:13: warning: unused variable ‘i’ [-Wunused-variable] 1916 | int i; | ^ io_decoder.c:1914:61: warning: unused parameter ‘buffer’ [-Wunused-parameter] 1914 | uint8_t in_expansion_routine(hal_io_decoder_t *io, uint8_t* buffer, uint8_t length) { | ~~~~~~~~~^~~~~~ io_decoder.c:1914:77: warning: unused parameter ‘length’ [-Wunused-parameter] 1914 | uint8_t in_expansion_routine(hal_io_decoder_t *io, uint8_t* buffer, uint8_t length) { | ~~~~~~~~^~~~~~ io_decoder.c: In function ‘out_expansion_routine’: io_decoder.c:1951:13: warning: unused variable ‘current_value’ [-Wunused-variable] 1951 | float_t current_value = 0; // Useremo un int32_t per gestire il valore | ^~~~~~~~~~~~~ io_decoder.c:1950:13: warning: unused variable ‘bytesWritten’ [-Wunused-variable] 1950 | uint8_t bytesWritten = 0; // Contatore dei byte letti dal buffer | ^~~~~~~~~~~~ io_decoder.c:1949:13: warning: unused variable ‘i’ [-Wunused-variable] 1949 | int i; | ^ io_decoder.c:1947:59: warning: unused parameter ‘dato’ [-Wunused-parameter] 1947 | void out_expansion_routine(hal_io_decoder_t *io, uint8_t* dato, uint8_t length) { | ~~~~~~~~~^~~~ io_decoder.c:1947:73: warning: unused parameter ‘length’ [-Wunused-parameter] 1947 | void out_expansion_routine(hal_io_decoder_t *io, uint8_t* dato, uint8_t length) { | ~~~~~~~~^~~~~~ io_decoder.c: In function ‘key_simulation_loop’: io_decoder.c:2032:53: warning: variable ‘suppress_base_key’ set but not used [-Wunused-but-set-variable] 2032 | int suppress_base_key = 0; // 0 = false, 1 = true | ^~~~~~~~~~~~~~~~~ io_decoder.c:2004:9: warning: unused variable ‘send_status’ [-Wunused-variable] 2004 | int send_status; | ^~~~~~~~~~~ io_decoder.c:2001:13: warning: unused variable ‘bitValue’ [-Wunused-variable] 2001 | uint8_t bitValue; | ^~~~~~~~ io_decoder.c: In function ‘calc_io_decoder’: io_decoder.c:2421:45: warning: unused parameter ‘period’ [-Wunused-parameter] 2421 | static void calc_io_decoder(void *arg, long period) { | ~~~~~^~~~~~ io_decoder.c: In function ‘rtapi_app_main’: io_decoder.c:2484:28: warning: unused variable ‘uidev’ [-Wunused-variable] 2484 | struct uinput_user_dev uidev; | ^~~~~ io_decoder.c:2471:20: warning: unused variable ‘i’ [-Wunused-variable] 2471 | int n, retval, i; | ^ io_decoder.c: In function ‘npic_in_routine’: io_decoder.c:1491:1: warning: control reaches end of non-void function [-Wreturn-type] 1491 | } | ^ io_decoder.c: In function ‘adc_routine’: io_decoder.c:1870:1: warning: control reaches end of non-void function [-Wreturn-type] 1870 | } | ^ io_decoder.c: In function ‘in_expansion_routine’: io_decoder.c:1945:1: warning: control reaches end of non-void function [-Wreturn-type] 1945 | } | ^ io_decoder.c: At top level: io_decoder.c:732:16: warning: ‘timer_overflow_0’ defined but not used [-Wunused-variable] 732 | static int timer_overflow_0 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:733:16: warning: ‘timer_overflow_1’ defined but not used [-Wunused-variable] 733 | static int timer_overflow_1 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:734:16: warning: ‘timer_overflow_2’ defined but not used [-Wunused-variable] 734 | static int timer_overflow_2 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:735:16: warning: ‘timer_overflow_3’ defined but not used [-Wunused-variable] 735 | static int timer_overflow_3 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:737:16: warning: ‘timer_overflow_5’ defined but not used [-Wunused-variable] 737 | static int timer_overflow_5 = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:739:16: warning: ‘handshake_init_dbg_printed’ defined but not used [-Wunused-variable] 739 | static int handshake_init_dbg_printed = 0; // Per HAL_STATE_HANDSHAKE_INIT | ^~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:740:16: warning: ‘handshake_response_dbg_printed’ defined but not used [-Wunused-variable] 740 | static int handshake_response_dbg_printed = 0; // Per HAL_STATE_HANDSHAKE_WAIT_RESPONSE | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:743:16: warning: ‘error_state_dbg_printed’ defined but not used [-Wunused-variable] 743 | static int error_state_dbg_printed = 0; // Per HAL_STATE_ERROR (primo ingresso) | ^~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:754:16: warning: ‘comm_packet_sent’ defined but not used [-Wunused-variable] 754 | static int comm_packet_sent = 0; | ^~~~~~~~~~~~~~~~ io_decoder.c:769:20: warning: ‘old_hand_valid_send’ defined but not used [-Wunused-variable] 769 | static int old_hand_valid_send = 0; | ^~~~~~~~~~~~~~~~~~~ io_decoder.c:771:20: warning: ‘old_hand_valid_received’ defined but not used [-Wunused-variable] 771 | static int old_hand_valid_received = 0; | ^~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:773:20: warning: ‘old_hand_invalid_send’ defined but not used [-Wunused-variable] 773 | static int old_hand_invalid_send = 0; | ^~~~~~~~~~~~~~~~~~~~~ io_decoder.c:775:20: warning: ‘old_hand_invalid_received’ defined but not used [-Wunused-variable] 775 | static int old_hand_invalid_received = 0; | ^~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:776:20: warning: ‘old_pin_debug2’ defined but not used [-Wunused-variable] 776 | static int old_pin_debug2 = 0; | ^~~~~~~~~~~~~~ io_decoder.c:783:21: warning: ‘old_usb_loop’ defined but not used [-Wunused-variable] 783 | static long old_usb_loop; | ^~~~~~~~~~~~ io_decoder.c:643:14: warning: ‘format_buffer_for_debug’ defined but not used [-Wunused-function] 643 | static char* format_buffer_for_debug(const unsigned char *buffer, int len) { | ^~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:148:12: warning: ‘printed_debug’ defined but not used [-Wunused-variable] 148 | static int printed_debug[100] = {0}; //serve a creare uno stop alle scritte di debug | ^~~~~~~~~~~~~ io_decoder.c: In function ‘usb_thread_function’: io_decoder.c:1297:28: warning: ‘usb2_current_time_ns’ may be used uninitialized [-Wmaybe-uninitialized] 1297 | usb_jitter_time_ns = usb_current_time_ns - usb2_current_time_ns; | ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:729:10: note: ‘usb2_current_time_ns’ was declared here 729 | long usb2_current_time_ns; | ^~~~~~~~~~~~~~~~~~~~ io_decoder.c:1297:28: warning: ‘usb_current_time_ns’ may be used uninitialized [-Wmaybe-uninitialized] 1297 | usb_jitter_time_ns = usb_current_time_ns - usb2_current_time_ns; | ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:728:10: note: ‘usb_current_time_ns’ was declared here 728 | long usb_current_time_ns; | ^~~~~~~~~~~~~~~~~~~ io_decoder.c:1308:38: warning: ‘next_parse_error_time_ns’ may be used uninitialized [-Wmaybe-uninitialized] 1308 | if ((current_time_ns - next_parse_error_time_ns) > parse_error_time_ns) { | ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c:726:10: note: ‘next_parse_error_time_ns’ was declared here 726 | long next_parse_error_time_ns; | ^~~~~~~~~~~~~~~~~~~~~~~~ io_decoder.c: In function ‘npic_out_routine’: io_decoder.c:1550:107: warning: ‘freq_conversion’ may be used uninitialized [-Wmaybe-uninitialized] 1550 | if (current_time_ns > (io->out_blink_time_ns[current_bit] + freq_conversion)) { | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~ io_decoder.c:1503:10: note: ‘freq_conversion’ was declared here 1503 | long freq_conversion; | ^~~~~~~~~~~~~~~ Linking io_decoder.so
“Bare-Metal” Firmware (No Bootloader)
We have removed the Arduino bootloader for two critical reasons:
Safety: No random pin state changes during startup (typical of bootloaders).
Speed: The board is operational within a few milliseconds.
what about updates ?
The following user(s) said Thank You: COFHAL, bobwolf
9 months 3 days ago #342167 by bobwolf
To clarify the threading model:
io_decoder
does not run the USB communication inside the Servo Thread.The component spawns its own dedicated asynchronous thread to handle the USB protocol. The interaction with LinuxCNC’s HAL happens via non-blocking data exchange.
  • Zero Blocking: The Servo Thread never waits for a USB response. It only reads/writes to a local buffer managed by the driver.
  • Base Thread Integrity: Because the USB communication is decoupled, there is no risk of inducing jitter in the software step-generation (Base Thread).
  • Responsiveness: This architecture allows us to maintain a high polling rate for the handwheel and I/O without affecting the machine's motion control stability.
This is exactly why it's more stable than a generic HID driver or a simple user-space script.
ciao
Roberto
9 months 3 days ago - 9 months 3 days ago #342169 by bobwolf
There's no direct support for a matrix keyboard; I had considered it during the project development phase, but I was too far along and would have had to completely overhaul everything... perhaps in a future version...
However, all the inputs have the keyboard functionality that allows them to send keyboard characters with the physical input pins.
the only difference is that you have to wire all the buttons one wire for each button + the common which must come from the io_decoder board
It's all explained in the docs on GitHub.
Last edit: 9 months 3 days ago by bobwolf.
9 months 3 days ago #342170 by bobwolf
halcompile --compile io_decoder.c Compiling realtime io_decoder.c MEGACUT [i][i][i][i][i][i]Linking io_decoder.so[/i][/i][/i][/i][/i][/i]
[i][i][i][i][i][i]“Bare-Metal” Firmware (No Bootloader) We have removed the Arduino bootloader for two critical reasons: Safety: No random pin state changes during startup (typical of bootloaders). Speed: The board is operational within a few milliseconds. what about updates ?[/i][/i][/i][/i][/i][/i]
Thank you for alerting me to all those warnings... apparently my system is set up so that I don't see them... I'll try to fix everything in the next few days... they're all warnings for things I left lying around due to closed roads and changes of direction in the program.
As for the choice to remove the bootloader, it's because I didn't want every communication, which occurs every 20ms, to waste time trying to figure out whether it was a new program or a regular message about the work it's doing.
If you want to modify the firmware, you need to use a programmer like tinyusb.
Moderators: PCW, jmelson
Time to create page: 0.425 seconds
