- Hardware & Machines
- Driver Boards
- hm2/hm2_5i25.0: invalid config name, got 'HOSTLOT2', expected 'HOSTMOT2'
- jtc
- Thank you received: 12
20 Jan 2026 06:51 #341609
by jtc
hm2/hm2_5i25.0: invalid config name, got 'HOSTLOT2', expected 'HOSTMOT2' was created by jtc
Hi to all!
After some months without using the machine and waste some time to bring the pc running again, I got this error trying load linuxcnc.
jtc@jtc-linuxcnc ~ $ /home/jtc/linuxcnc-dev/scripts/linuxcnc /home/jtc/linuxcnc-dev/configs/kondia/kondia.iniLINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jtc/linuxcnc-dev/configs/kondia'
Machine configuration file is 'kondia.ini'
Starting LinuxCNC...
Found file(REL): ./kondia.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:05:00.0
hm2_5i25.0: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7f59c3c27000
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
./kondia.hal:8: waitpid failed /home/jtc/linuxcnc-dev/bin/rtapi_app hm2_pci
./kondia.hal:8: /home/jtc/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./kondia.hal:8: insmod for hm2_pci failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/jtc/linuxcnc_debug.txt
and
/home/jtc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Any help will be welcome,
Regards
hm2: unloading
and
Regards
- Thank you received: 5336
20 Jan 2026 10:22 #341611
Replied by PCW on topic hm2/hm2_5i25.0: invalid config name, got 'HOSTLOT2', expected 'HOSTMOT2'
Looks like a bad bit on the PCI interface.
If the card has not been mechanically damaged, the most likely
cause would be dirty contact fingers on the 5I25 or dirty slot
contacts on the PCI slot.
As a first attempt to fix, I would clean the 5I25 contact fingers
and PCI slot contacts with 99% IPA or other contact cleaning solution.
- jtc
20 Jan 2026 14:29 #341626
by jtc
Replied by jtc on topic hm2/hm2_5i25.0: invalid config name, got 'HOSTLOT2', expected 'HOSTMOT2'
After this make this thread I remove the card for inspection, and when I plugged it again it works fine. Somehow the pci slot develop a bad connection.
Solved for now! Thanks
- Driver Boards
Time to create page: 0.127 seconds
