hm2_modbus pktuart, probably a firmware request?
8 months 1 week ago #343432 by PCW
I'll try and get to the 7I96 configuration later today or tomorrow
but note you need a  RS-485 interface, and that's only available on the 7I96 configuration.
The 7I92 configs  would need to add a RS-485 chip or a daughtercard with a RS-485 interface.
8 months 1 week ago #343481 by PCW
This should be close
File Name: 7i96d_7i85p_pktv3.zip
File Size:128.01 KB
Note that I had to reduce the number of sserial channels to 3 to fit
(the are also renumbered so channels 0,1,2 are on 7i85 channels 0,1,2)
8 months 1 week ago #343486 by jtrantow
That should work!
Do you need to assign the pktuart pins when you build the firmware?
If yes, the Mill with 7i92 has open connectors on the 7i85S TB1 TX6, TX7 SRX0, STX0 and all the odd I/O on the 7i75.
The Router with 7i92T supports a spindle, laser, and bunch of pins reserved for plasma.
P1 and P2 are both configured as G540 but P1 is actually connected to 7i75 card.
The pins I have unassigned are P1 gpio.029, .031, and 0.033.
The router is working fine and won't gain any functionality so an update is much lower priority. Really just a wiring cleanup so let's wait before putting new firmware in that.
I will try to get the  7i96d_7i85p_pktv3  installed today, otherwise it may be a week before I get back to it.
Thanks!
8 months 1 week ago #343498 by jtrantow
That should work!
Thanks!
8 months 1 week ago #343499 by PCW
The physical PKTUART pins are assigned in the firmware source (the PIN_XXXXX.vhd file that was included in the zip file)
 (If that's what you meant)
Moderators: PCW, jmelson
Time to create page: 0.060 seconds
