7i76EU+7i85+7i84U
- Thank you received: 1476
24 Feb 2026 16:02 #343405
7i76EU+7i85+7i84U was created by Todd Zuercher
First time using a Mesa Ethernet board and I'm trying to set up a new install. I think I've flashed the right firmware to the 7i76eu. But I can't seem to see the 7i84u card that I have plugged into the first serial connector on the 7i85. The encoders seem to be working on the 7i85, but I can't seem to make the 7i84u work. On the 7i85u CR2 and CR7 are on yellow and CR5 is on red. Not sure what I'm doing/have done wrong.
Here's the output of mesaflash --device 7i76eu --addr 10.10.10.10 --readhmid
twincnc@twincnc:~$ mesaflash --device 7i76eu --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I76
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 160.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for on-card -> 7I76
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB2-4,5 0 IOPort StepGen 0 Dir/Table2 (Out)
TB2-2,3 1 IOPort StepGen 0 Step/Table1 (Out)
TB2-10,11 2 IOPort StepGen 1 Dir/Table2 (Out)
TB2-8,9 3 IOPort StepGen 1 Step/Table1 (Out)
TB2-16,17 4 IOPort StepGen 2 Dir/Table2 (Out)
TB2-14,15 5 IOPort StepGen 2 Step/Table1 (Out)
TB2-22,23 6 IOPort StepGen 3 Dir/Table2 (Out)
TB2-20,21 7 IOPort StepGen 3 Step/Table1 (Out)
TB3-4,5 8 IOPort StepGen 4 Dir/Table2 (Out)
TB3-2,3 9 IOPort StepGen 4 Step/Table1 (Out)
Internal-Field-IO 10 IOPort SSerial 0 TXData0 (Out)
Internal-Field-IO 11 IOPort SSerial 0 RXData0 (In)
TB3-18,19 12 IOPort SSerial 0 TXData1 (Out)
TB3-16,17 13 IOPort SSerial 0 RXData1 (In)
TB3-13,14 14 IOPort MuxedQCount 2 MuxQ-IDX (In)
TB3-10,11 15 IOPort MuxedQCount 2 MuxQ-B (In)
TB3-7,8 16 IOPort MuxedQCount 2 MuxQ-A (In)
IO Connections for P1
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 17 IOPort SSerial 0 RXData6 (In)
14 18 IOPort SSerial 0 TXData6 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData5 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData4 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort SSerial 0 TXData3 (Out)
5 25 IOPort SSerial 0 RXData2 (In)
6 26 IOPort SSerial 0 TXData2 (Out)
7 27 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 28 IOPort MuxedQCount 0 MuxQ-A (In)
9 29 IOPort MuxedQCount 0 MuxQ-B (In)
10 30 IOPort MuxedQCount 0 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 1 MuxQ-A (In)
12 32 IOPort MuxedQCount 1 MuxQ-B (In)
13 33 IOPort MuxedQCount 1 MuxQ-IDX (In)
IO Connections for P2
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None Please Log in or Create an account to join the conversation.
- Thank you received: 7485
24 Feb 2026 16:09 #343407
Replied by tommylight on topic 7i76EU+7i85+7i84U
7i84 requires having field power on both section for all IO to show up, not sure about the 7i84U.
Is the field power applied to the 7i84U?
- Thank you received: 5328
24 Feb 2026 16:11 - 24 Feb 2026 16:17 #343409
Replied by PCW on topic 7i76EU+7i85+7i84U
Is sserial channel 2 enabled in the hal file?
(something like : "sserial_port_0=000xxxxx" in the driver command line)
Also
mesaflash --device 7i76eu --addr 10.10.10.10 --dbname2 7i85 --readhmid
would list the 7I85 pins, not DB25 pins
Also
Last edit: 24 Feb 2026 16:17 by PCW.
24 Feb 2026 16:26 #343412
Replied by Todd Zuercher on topic 7i76EU+7i85+7i84U
Yes, the field power is connected.
I have this for the config line in hal
Here's the output from mesaflash;
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=5 num_pwmgens=0 num_stepgens=5 sserial_port_0=0000000x"Here's the output from mesaflash;
twincnc@twincnc:~$ mesaflash --device 7i76eu --addr 10.10.10.10 --dbname2 7i85 --readhmid
FPGA Pins: 256
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: MuxedQCount
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
IO Connections for P1 -> 7I85
TB1-19,20 17 IOPort SSerial 0 RXData6 (In)
TB1-21,22 18 IOPort SSerial 0 TXData6 (Out)
TB1-11,12 19 IOPort SSerial 0 RXData5 (In)
TB1-13,14 20 IOPort SSerial 0 TXData5 (Out)
TB1-3,4 21 IOPort SSerial 0 RXData4 (In)
TB1-5,6 22 IOPort SSerial 0 TXData4 (Out)
TB2-19,20 23 IOPort SSerial 0 RXData3 (In)
TB2-21,22 24 IOPort SSerial 0 TXData3 (Out)
TB2-11,12 25 IOPort SSerial 0 RXData2 (In)
TB2-13,14 26 IOPort SSerial 0 TXData2 (Out)
Internal-EncMux 27 IOPort MuxedQCountSel 0 MuxSel0 (Out)
TB3-1,2,9,10 28 IOPort MuxedQCount 0 MuxQ-A (In)
TB3-4,5,12,13 29 IOPort MuxedQCount 0 MuxQ-B (In)
TB3-7,8,12,13 30 IOPort MuxedQCount 0 MuxQ-IDX (In)
TB3-17,18,TB2-1,2 31 IOPort MuxedQCount 1 MuxQ-A (In)
TB3-20,21,TB2-4,5 32 IOPort MuxedQCount 1 MuxQ-B (In)
TB3-23,24,TB2-7,8 33 IOPort MuxedQCount 1 MuxQ-IDX (In)
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
twincnc@twincnc:~$Please Log in or Create an account to join the conversation.
24 Feb 2026 16:43 - 24 Feb 2026 17:13 #343413
Might be cable wiring (if you never even get a green blink from the 7I84U, there is no communication)
As tommylight asked, do you have both field powers applied ( A and B )?
Last edit: 24 Feb 2026 17:13 by PCW.
24 Feb 2026 16:56 #343414
24 Feb 2026 17:15 #343416
Yes both A and B.
24 Feb 2026 17:38 #343419
24 Feb 2026 18:37 #343420
I'll test this setup later today.
- Thank you received: 4149
24 Feb 2026 22:40 #343436
Replied by rodw on topic 7i76EU+7i85+7i84U
Take care here, Network cabling comes in two different flavours T568B and T568A. Google for the difference
In my case, Mesa's serial port manual describes one of these standards but in my country the normal standard was the other!
I drew up my own pin out diagram converting the wire colours to be correct and my 7i73 woke up!
Time to create page: 0.259 seconds
