7i76EU+7i85+7i84U
- Thank you received: 7485
24 Feb 2026 22:42 #343437
Replied by tommylight on topic 7i76EU+7i85+7i84U
Did it sleep well ?I drew up my own pin out diagram converting the wire colours to be correct and my 7i73 woke up!
- Thank you received: 4149
24 Feb 2026 22:47 #343438
Replied by rodw on topic 7i76EU+7i85+7i84U
Yes, it was sleeping for days before it received the kiss of life!
- Thank you received: 5328
24 Feb 2026 23:08 #343439
Replied by PCW on topic 7i76EU+7i85+7i84U
Yes, it may be a cable issue.
Just verified that:
7i76eu_7i76x1_7i85x1d.bin from the distribution zip file.
md5 checksum:
485114d3d22390a7e5b44d77588981c5 7i76eu_7i76x1_7i85x1d.bin
Works correctly with a 7I85 on P1 (all 5 sserial ports on the 7I85 work correctly)
Is it possible you have a 7I85S rather than 7I85?
Just verified that:
md5 checksum:
- Thank you received: 1476
25 Feb 2026 00:00 #343441
Replied by Todd Zuercher on topic 7i76EU+7i85+7i84U
It's supposed to be a 7i85 not a 7i85s. I'll have to check it in the morning.
I'll also have to check the piece of patch cable I used. It's possible the cable could be suspect.
25 Feb 2026 11:41 #343459
I have it working now. I had my serial cable wired wrong. (I had the polarity of the RX and TX wires wrong.)
