- Thank you received: 7491
Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
6 months 3 weeks ago #345418
Replied by tommylight on topic Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
Can you make a new very simple config and test again?
- adhamamer
6 months 2 weeks ago - 6 months 2 weeks ago #345423
by adhamamer
Replied by adhamamer on topic Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
I tried on a Raspberry Pi 4 with image "image_2026-01-21-raspios-lcnc-2.9.8-trixie-arm64"
and on a Laptop with image "linuxcnc_2.9.8-amd64.hybrid"
and unfortunately i get the same results on both, with the simplest configs i can do, even in the test/tune tab in pnc wizard it acts the same way, Sorry guys i may be missing something really basic here, do you think it might be the firmware?
config name "GG" made on the laptop
Files attached
Files attached
Last edit: 6 months 2 weeks ago by adhamamer.
- Thank you received: 5334
6 months 2 weeks ago #345424
Replied by PCW on topic Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
The hal and ini file look sane so I would guess its some kind of hardware issue.
So the card should be returned for evaluation
- adhamamer
6 months 2 weeks ago #345425
by adhamamer
You think it's worth it to give it another shot with flashing another firmware before returning it or do you advice against that?
6 months 2 weeks ago #345426
Unless you changed the firmware, I doubt that that's the issue.
(all cards are tested and shipped with standard firmware)
The following user(s) said Thank You: adhamamer
- adhamamer
6 months 1 week ago #345824
by adhamamer
Update:
MESA Replied:“OK, examined the cardU15 (STEP+/DIR+ 0..3 driver) and RN31 (27 Ohm resistor networkin series with STEPO+/DIRO+ and STEPO-/DIRO- pins) were both damaged.RN31 had opens on the STEPO+ and DIRO+ pins.Damage was likely caused by connection of theSTEPO+,DIRO+ pinsto either something outside the 0 to +5V range (even briefly) ora long time short of the STEPO+,DIRO+ pins to 5V or ground.”
Im pretty confident that i did not cause this damage, all the wiring Ive done on tb2 was also done on tb3 to a standard tb6600 stepper driver
What do you guys think i should do?
Time to create page: 0.495 seconds
