7i92tm + 2xbob
4 months 1 week ago #347234 by PCW
Replied by PCW on topic 7i92tm + 2xbob
Unless you can get a MPG with open collector outputs ( that match the SainsSmart BOB inputs ),
you are probably better off connecting the MPG  directly to the 7I92.
4 months 1 week ago - 4 months 1 week ago #347235 by Masiwood123
Replied by Masiwood123 on topic 7i92tm + 2xbob
In that case, if I do a mesaflash for two Bobs, will the configuration work using only one Bob as the base, for example the p1 port, and the other port directly from the card?How would you configure it for my case?
Last edit: 4 months 1 week ago by Masiwood123.
4 months 1 week ago #347237 by Ul
Replied by Ul on topic 7i92tm + 2xbob
You still need to pay customs if you buy from the EU? Didn't that change two decades ago or so?
Anyway - there are cheap clones of the 7i92 on Aliexpress which work the same way like the original, with original Mesa bitfiles. May be worth trying, but they are going more and more expensive very fast. Or does Aliexpress stuff still disappear in Serbian post?
4 months 1 week ago #347238 by PCW
For passive BOBs like the SainSmart ones, the configuration with or without  BOB is Identical
The following user(s) said Thank You: Masiwood123
4 months 1 week ago #347240 by Masiwood123
works on aliexpress and the Temu normally now, Aliexpress has customs duties..otherwise nothing has changed here for 3 decades, it's just getting worse and worse, I have the option of purchasing from EU countries that don't have customs duties but have taxes so it comes the same :(
Moderators: PCW, jmelson
