Mesa 7i92TM+7i77+7i76U configuration
- Firehunter
17 Aug 2026 09:48 #348807
by Firehunter
Mesa 7i92TM+7i77+7i76U configuration was created by Firehunter
I currently have a machine that uses a combination of a Mesa 7i92TM and 7i77. But all axis outputs are used and I need another axis for a toolchanger. I want to use a 7i76U for step/dir controlling a servo. Can I use the 7i92t_7i77_7i76d.bin for this or is the 7i76U a different board? If I need an other .bin file, can someone make it for me?
- Thank you received: 7501
17 Aug 2026 14:23 #348812
Replied by tommylight on topic Mesa 7i92TM+7i77+7i76U configuration
Moved to "driver boards".
- Thank you received: 5335
17 Aug 2026 16:29 - 17 Aug 2026 16:32 #348816
Replied by PCW on topic Mesa 7i92TM+7i77+7i76U configuration
7i92t_7i77_7i76d.bin is fine for a 7I92T + 7I77 / 7I76U setup.
The only case where 7I76U specific FPGA firmware is needed
is when you want to use the 7I76U's serial port in RS-485 mode
(say for Modbus), but even if you need Modbus, you could use the
7I77s serial port (that natively supports RS-485) for that.
Last edit: 17 Aug 2026 16:32 by PCW.
- Firehunter
19 Aug 2026 19:23 #348862
by Firehunter
Replied by Firehunter on topic Mesa 7i92TM+7i77+7i76U configuration
Okay, thanks! Is the .bin file for 7i77 the same as for 7i77U?
19 Aug 2026 19:54 #348864
Yes, the 7I77U is identical to the 7I77 and 7I77D FPGA interface wise.
Time to create page: 0.073 seconds
