7I80HD-T: st8_plasma bitfile build request
- WMCVegas
17 Aug 2026 14:55 #348814
by WMCVegas
7I80HD-T: st8_plasma bitfile build request was created by WMCVegas
Hi, I'm building a plasma table (QtPlasmaC, THCAD-300) around a 7I80HD-T and would like to run the ST8_PLASMA config — 8 stepgens plus the two encoder inputs is exactly the right fit for this machine.
I see PIN_ST8_PLASMA_72.vhd ships in the 7i80hdt.zip hostmot2 source, but there's no prebuilt 7i80hdt_st8_plasma.bin among the stock configs, looks like it was only ever built for the Spartan 7I80HD.
Any chance of getting a Trion build of that config a test. If it's easier to point me at the Efinity project setup to build it myself, that works too.
Thanks!
Thanks!
- Thank you received: 5335
17 Aug 2026 16:33 #348817
Replied by PCW on topic 7I80HD-T: st8_plasma bitfile build request
The following user(s) said Thank You: WMCVegas
- WMCVegas
17 Aug 2026 18:08 #348819
by WMCVegas
Replied by WMCVegas on topic 7I80HD-T: st8_plasma bitfile build request
Thank you!
Time to create page: 0.073 seconds
