Sudden lost of Y2 slave control
  • scsmith1451
  • scsmith1451's Avatar Topic Author
  • Premium Member
  • Premium Member
18 Sep 2026 14:13 #349711 by scsmith1451
Sudden lost of Y2 slave control was created by scsmith1451
Hi all;
My question is simple. No changes have been made to wiring or configuration, yet Y2 stopped working. I verified connectivity between the motor and the breakout board, all is good. I next tried swapping the plug position between my A axis and the Y2 axis, modified the hal file to reflect the swap and restarted LCNC. Now the X axis has joined the problem. Z still responds correctly.
What is more likely, a failure of my MESA 7i76U driver board or the breakout board or both?
Kind Regards,
18 Sep 2026 14:31 #349712 by tommylight
Replied by tommylight on topic Sudden lost of Y2 slave control
My crystal ball has stopped working....
More info, pictures, configs...
18 Sep 2026 21:35 #349732 by PCW
Replied by PCW on topic Sudden lost of Y2 slave control
On a 7I76U, if any of the 0..3 stepgen STEP or DIR outputs on TB2  have been
damaged, all 4 may be affected as they are driven by the same chips.
(U8 = 74ACT540  for the - outputs and U12 = 74ACT541 for the + outputs)
  • scsmith1451
  • Premium Member
  • Premium Member
19 Sep 2026 12:01 #349735 by scsmith1451
Replied by scsmith1451 on topic Sudden lost of Y2 slave control
Thanks PCW;
Would it be more cost effective to replace the board or have it repaired?
Kind Regards,
19 Sep 2026 17:39 #349737 by PCW
You might do a simple output voltage check with no load to make sure the issue is with the 7I76U card
All  step/dir outputs should measure very close to 5V or 0V. nay on between voltages suggest a damaged
output driver chip
Mesa can repair the card for a nominal charge but shipping will add up.
The following user(s) said Thank You: scsmith1451
  • scsmith1451
  • Premium Member
  • Premium Member
21 Sep 2026 15:11 #349764 by scsmith1451
Good morninig PCW;
Checked the voltages at the micro-stepper plugs this morning, all read either 0 v or 4.12 v, nothing in between. Although the high voltage is a bit low, I think it is within operational range. I'm not using an external 5 v supply for the board, though I have one to run my crosshair laser, so I could tap that supply if necessary. All of my dedicated power supplies 5, 12, 24 and 36 v are spot on their output voltages.
Not sure if it is the 7i76U or the 6i25 FPGA, which is configured as a 5i25, in the computer or something else that could be the issue. What is your suggestion at this point?
21 Sep 2026 16:37 #349768 by PCW
You might try measuring at the 7I76U with the plugs removed
though 4.12V sounds OK under load. (its really marginal with no load however)
I can post a program a bit later today that will toggle all the step/dir outputs
slowly for a more complete test.
21 Sep 2026 18:49 - 21 Sep 2026 21:05 #349772 by PCW
Here is a little test program that slowly toggles all step/dir outputs so both states of all outputs
can be checked with a voltmeter:
File Name: 5i25stepgens.txt
File Size:1 KB
You will need to
chmod +x 5i25stepgens.txt
then
sudo ./5i25stepgens.txt
and all step/dir outputs should toggle at a ~ 1/3 hz rate
Last edit: 21 Sep 2026 21:05 by PCW.
  • scsmith1451
  • Premium Member
  • Premium Member
24 Sep 2026 12:47 #349838 by scsmith1451
After updating the mesaflash app, I tried starting mesaflash. No errors were reported, however, the output were not toggling. Checking the man page, I could not identify any option to keep the pins toggling until the app was cancelled. Since the electronics are located on the back of the machine it requires more that 1-3 secs to move from the keyboard to the board to measure the outputs. Checking currently running programs (ps -ef | grep mesa), no app containing the string "mesa" was running. Is there a hidden option that will keep the app running until cancelled?
However, checking all of the outputs, all voltages were sitting at 4.92 v. What are the next steps for diagnosing issues with the 7i76U?
Kind regards,
24 Sep 2026 18:33 #349847 by PCW
The step/dir outputs should continue toggling indefinitely.
At this point I would ask for a RMA# from Mesa and return both the 7I76U and the FPGA card for
analysis/repair/replacement.
Moderators: PCW, jmelson
Time to create page: 0.146 seconds
