Sudden lost of Y2 slave control
- scsmith1451
- Thank you received: 3
21 Oct 2026 16:26 #350384
by scsmith1451
Replied by scsmith1451 on topic Sudden lost of Y2 slave control
Hi PCW;
I reinstalled the boards and then verified with halshow that all of the field input switches were functioning correctly. With the spindle located in the middle of the table I started the homing sequence. Z and X both homed properly, however, when Y started the homing process a, "joint.1 failed to unhome" message was presented 3 times then joint.1 began to home while joint2. failed to move.
The machine is configured with both the Y and the Y2 axes (joint.1 and joint.2) set up with "both limits and home" switches using a single input for each axis. Thus, neither axis home switch was triggered yet LINUXCNC could not logically unhome one of the two axes.
What is the next step to resolve this issue?
Kind Regards,
Kind Regards,
- Thank you received: 5329
21 Oct 2026 17:21 #350386
Replied by PCW on topic Sudden lost of Y2 slave control
One way to debug this might be to do a halscope plot of the homing sequence.
That is, plot the home switch states and Y +Y1 motion during a homeĀ
move.
move.
Time to create page: 0.087 seconds
