7I96 and MPGs?
27 Sep 2026 19:27 #349934 by Holzwurm56
7I96 and MPGs? was created by Holzwurm56
Hello,
i have install LCNC with a 7I96 for a lathe. There a two mpgs connected the first mpg on pin 0 + 1 and the other mpg on pin 2 + 3 from connector
TB3. Is there a sample for the hal-file to use the mpgs for nturning in manual mode?
Hans
27 Sep 2026 21:51 #349939 by PCW
Replied by PCW on topic 7I96 and MPGs?
If this is a 7I96 and not a 7I96S, you would need 7i96_inmd.bit firmware installed.
has this been done?
28 Sep 2026 05:50 #349945 by Holzwurm56
Replied by Holzwurm56 on topic 7I96 and MPGs?
The firmware is installed. The mpg counts, but there is no connection to axis.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
28 Sep 2026 08:26 #349947 by rodw
Replied by rodw on topic 7I96 and MPGs?
You should be able to follow the MPG example in the  docs. It is for a parallel port but its really all the same with a Mesa card. I had no troubles with a 7i76e. You probably don't need the axis select......
Moderators: PCW, jmelson
Time to create page: 0.071 seconds
