Firmware request: 7i96s with modbus/PktUART and 7i85 daughercard
26 Oct 2026 09:03 #350464 by JThom
Hello,
I think I need custom firmware/bit-files for my setup.
I have a 7i96s with 7i85 db25 daughter-card, which in turn has 4 encoders, a 7i84u and a 7i73 attached. I want to control my Invertek ODE-3 spindle vfd with modbus from rs485 on the 7i96s.
Unless I'm mistaken, the standard 7i96s_7i85d files don't feature PktUART for modbus on the 7i96s. Everything else seems to be working with them.
It's a 4 axis mill, so if possible, I also wish to retain the encoder input on the 7i96s for a spindle encoder - (if i understand correctly there can be complications there due to muxed vs unmuxed?).
I've had a look for existing firmware, but don't notice a suitable option in the standard 7i96s package.
I also read the below linked thread, but don't see links for bit/pin files there.
www.forum.linuxcnc.org/27-driver-boards/...dbus-pkt-pin?start=0
Would this be possible please? Any other information needed?
26 Oct 2026 10:58 - 26 Oct 2026 11:00 #350465 by PCW
7I96S  + 7I85 with PktUART on 7I96S RS-485 interface
Note that sserial channel numbering on the 7I85 has changed
since old sserial channel 0 on the 7I96S has been replaced by
a PktUART, so sserial channels 0..4 instead of 1..5 are on the 7I85.
Encoder on the 7I96S is encoder 4  (same as normal 7I96S+7I85 configuration)
File Name: 7i96s_7i85_pktv3d.zip
File Size:307 KB
Last edit: 26 Oct 2026 11:00 by PCW.
The following user(s) said Thank You: JThom
26 Oct 2026 11:07 #350466 by JThom
Thank you! Mesa customer service is outstanding.
Moderators: PCW, jmelson
Time to create page: 0.184 seconds
