Problems connecting to 7i96s
- PetersonTools
17 Nov 2026 09:57 #350775
by PetersonTools
Problems connecting to 7i96s was created by PetersonTools
I been trying to connect to my 7i96s board,
Right know i have it connected via ethernet with the default EEPROM IP and set my pc ip to 10.10.10.1, i been able to ping the board but the moment i start the PnCConf wizard and try to discover the board and connect to it the CR7 led turns on.
What could be happening?
- Thank you received: 7506
17 Nov 2026 10:10 #350776
Replied by tommylight on topic Problems connecting to 7i96s
Usually a bad power supply, so try another better one, must be 5V and from 0.5A (500mA) to whatever A does not matter.
OR
Take a good thick USB cable and cut it, use the red and black wire to power the Mesa.
Mind the polarity, 5V is red, usually, but if you have a DVM do check that before powering on.
OR
- Thank you received: 5337
17 Nov 2026 10:12 #350777
Replied by PCW on topic Problems connecting to 7i96s
If CR7 (/DONE) turns on when the card is accessed, that most likely indicates a marginal
5V power source that drops out as soon as the card draws a bit more power.
Also you should not need the discover option unless you are using non standard firmware.
It is normal for CR8 (/INIT) to illuminate when exiting LinuxCNC, as it indicates a watchdog bite.
Time to create page: 0.075 seconds
