Easy Question - Best Orientation of Mesa Boards?
- GeckoWorks
- Thank you received: 9
19 Nov 2026 00:29 - 19 Nov 2026 00:30 #350811
by GeckoWorks
Easy Question - Best Orientation of Mesa Boards? was created by GeckoWorks
I am finally beginning my first LCNC build and I have an easy question. For my main and daughterboard - what's the best orientation/order?
Mother before daughter or the other way around?
I am sure it can be done many ways, but thought some of you guys who have wired up these before might have a preference:)
The boards are in the lower, right hand corner of the cabinet. As far away from the VFD, servo drives and mains power as I could practically put them.
As an aside I 3D printed some Mesa holders. I know there are some good ones out there already but I wanted to use some store bought DIN rail adapters and then one thing led to another:
Last edit: 19 Nov 2026 00:30 by GeckoWorks.
- Thank you received: 7509
19 Nov 2026 06:11 #350820
Replied by tommylight on topic Easy Question - Best Orientation of Mesa Boards?
When space is not an issue, i always orient them same as in the manual.
If space is an issue, however i can, minding signaling being as far from big power users when routing cables.
- GeckoWorks
19 Nov 2026 06:24 #350822
by GeckoWorks
Replied by GeckoWorks on topic Easy Question - Best Orientation of Mesa Boards?
Yeah, I have them with the silkscreen being right side up. But do you have any preference as to whether you would have a daughterboard to the left or the right of the main board?
Thing is, I haven't ever wired one of these up so maybe there's trick not to be missed here:)?
- Thank you received: 4662
19 Nov 2026 06:53 #350825
Replied by andypugh on topic Easy Question - Best Orientation of Mesa Boards?
You probably need a bit more space to get the Cat5 cable plugged in...
Have you reversed the power connections? (not the polarity, I mean the wire entry direction)
Personally I would put the motherboard to the left of the daughter board, but not for any logical or technical reason, just because I lay out schematics with data flow from left to right.
- GeckoWorks
19 Nov 2026 07:13 #350828
by GeckoWorks
Yeah, the CAT5 cable is indeed taking up more space than I thought - I just wired one up. But I have some right angle connector cables on the way that should buy me back some space as I don't really have much of that left.
As for the power cable, it's wired up correctly but it was confusing to me, too - I would have thought the wires going away from the board would have been normal. But this is how mine came. I guess I could desolder the connector and turn it 180d, but I will probably not bother:)
- rubes
19 Nov 2026 08:24 #350833
by rubes
Replied by rubes on topic Easy Question - Best Orientation of Mesa Boards?
power connector on my 7i96s is the same (wires exiting towards center of board)
Time to create page: 0.184 seconds
