Linux way to configure Mitsubishi MELSERVO drivers
20 Nov 2026 10:32 #350852 by michaelshiloh
I picked up a number of Mitsubishi MELSERVO drivers, MR-J3-40BS, along with their AC servo motors. They want a configuration program (called Mr Configurator, honestly) which of course runs only on Windows. Is there a Linux way to configure these things? I don't own a Windows computer and have no wish to start now.
20 Nov 2026 12:04 - 20 Nov 2026 14:45 #350854 by Todd Zuercher
Replied by Todd Zuercher on topic Linux way to configure Mitsubishi MELSERVO drivers
Are you opposed to trying to run the software in a Windows virtual machine? That may be the closest you can get to running this in a Linux environment. Wine seems unlikely to work, but it might still be worth a try, but I don't think I'd try to install it on your Linuxcnc PC.  Use a separate PC or a Laptop to run the config software.
I stopped using Windows at home years ago, but I still keep a couple Windows VMs around for those "just in case" moments. Truth be told, it's been more than 2 years since I last even tried to start one of those VMs. I'm still forced to use Windows at work though. For some reason our IT dept. seems to have something against Linux, I've even heard them use the phrase "rouge Linux machine" a couple of times.
Last edit: 20 Nov 2026 14:45 by Todd Zuercher.
20 Nov 2026 17:13 #350861 by dbtayl
Can't speak to the software specified, but I ran the DMM DYN4 configuration software via WINE. It works, but had hard-coded serial ports instead of listing those from your system, so I had to do a symlink to get the /dev/ttyUSBx serial port to show up as COM[0-8] for it to play nice.
The Teknic ClearPath software didn't play so nice and I ended up borrowing a Windows machine. So... YMMV, but worth a shot IMO.
Sidebar re: IT not liking Linux machines... I try to remind myself that they've got an impossible job trying to keep a fleet relatively secure-ish, given the wild things users can and will do, and that they don't have the tools/training/bandwidth/etc. to deal with one guy wanting to use Linux/BSD/whatever. Still maddening, but at least humanizes it a bit.
Moderators: PCW, jmelson
