Anyone out there have Compumotor ZETA Drivers?
- wireb
20 Mar 2011 01:30 #7944
by wireb
Anyone out there have Compumotor ZETA Drivers? was created by wireb
If so what values did you use for setup and hold on step and direction. Manual is less than helpful on this.
- wireb
20 Mar 2011 01:34 #7945
by wireb
Replied by wireb on topic Re:Anyone out there have Compumotor ZETA Drivers?
Apparently I am blind. Just re-read the manual for the 10th time and found it.
Anyone else who happens to need the info....
15ma max in
3.5V to 5.2V in
200ns on time
200ns off time
2MHz max rate
optically isolated
No timing specs on direction but the rest of the spec are the same.
15ma max in
3.5V to 5.2V in
200ns on time
200ns off time
2MHz max rate
optically isolated
- BigJohnT
- Thank you received: 1176
20 Mar 2011 16:05 #7949
by BigJohnT
Replied by BigJohnT on topic Re:Anyone out there have Compumotor ZETA Drivers?
- wireb
20 Mar 2011 22:31 #7959
by wireb
Done
- Thank you received: 2160
21 Mar 2011 02:58 #7967
Replied by cmorley on topic Re:Anyone out there have Compumotor ZETA Drivers?
What motors are you using? I have these drives on a test minimill. I use parker steppermotors.
- wireb
21 Mar 2011 03:11 #7968
by wireb
compumotor S57-102-MO
Got it up and running late last night
Full build notes here if anyone is curious
www.cnczone.com/forums/diy-cnc_router_ta...-junkbox_18x7x7.html
Time to create page: 0.216 seconds
