Mesa 7i48 vs 7i33
- doug6949
15 Apr 2011 14:08 #8944
by doug6949
Mesa 7i48 vs 7i33 was created by doug6949
This is my first emc build. I am looking at the Mesa 7i48 because it offers 6 axis instead of the 4 on the 7i33. There is some discussion of the 7i48 in the "5 axis build" thread but not much else that discusses user observations.
Which of you are using the 7i48 and what problems have you encountered? I recall that configuration wizards were being built into V2.5. Are they complete? Anything else I should know before ordering cards?
Thanks;
Doug
Thanks;
Doug
- Online
- Thank you received: 5254
15 Apr 2011 23:47 #8979
Replied by PCW on topic Re:Mesa 7i48 vs 7i33
The main limitation of the 7I48 is that you must use the development version of EMC, (version 2.5 or greater) as it is not supported
in the last released version (2.4.6). It is also not supported by pncconf so you must created a HAL file by hand (Starting with the hm2-servo HAL file is a good start)
- Thank you received: 2160
16 Apr 2011 08:08 #8982
Replied by cmorley on topic Re:Mesa 7i48 vs 7i33
pncconf partially supports the 7i48 in EMC 2.5.
You can configure half the mux encoders. Then you could hand edit for the other half.
- xolotl4
13 Jun 2013 23:18 #35596
by xolotl4
Replied by xolotl4 on topic Re:Mesa 7i48 vs 7i33
Hi, is the 7i48 fully supported now (LinuxCNC 2.5.2)? witch firmware should i load to use the 6 axis?
Time to create page: 0.057 seconds
