LinuxCNC v2.9.6 Released
  • andypugh
  • andypugh's Avatar Topic Author
  • Moderator
  • Moderator
26 Sep 2025 11:41 #335451 by andypugh
LinuxCNC v2.9.6 Released was created by andypugh
LinuxCNC 2.9.6 has been released.
This is a bug-fix release. Shortly after the release of 2.9.5 it was
noticed that a fix for a graphics bug in Gmoccapy had resulted in the
Axis touch-off dialog box no-longer working for non-zero entries.
This update is for all users, but especially users of the Axis GUI.
Packages for 2.9-uspace for amd64 (PC) for Debian Buster, Bullseye,
Bookworm and Trixie and for arm64 (Raspberry Pi 4/5) for Buster and
Bookworm have been added to the linuxcnc repository. If you installed
from one of our live images or Pi SD-card images then the update
should be available immediately.
If you installed into a normally-installed Debian from the Debian
repositories then hopefully the new version can be queued up for the
next point release. If you can’t wait then it is possible to add the
LinuxCNC repositories to the apt sources. One way to do this and
install the security keys is via the shell script here:
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
At the moment the live-image installer and SD card images will install
2.9.4 but update should be trivial (and possibly automatic)
RTAI is still supported, but in the short term building from source is
likely to be the most expedient way to get 2.9.6 on that platform.
Changelog
qtvcp -Qt5_graphics: issue 2753; preview wrongly uses INI startup code
Merge pull request #3567 from Sigma1912/2_9-Correct_bad_fix_for_2753
Gremlin: Don’t use RS274NGC_STARTUP_CODE when updating the preview
Docs: Address G52 Circular Link #3565
Acknowledgements
As always, we couldn’t do this without the contributions from the
community, so many thanks to:
CMorley
Sigma1912
15 Oct 2025 06:03 #336477 by tommylight
Replied by tommylight on topic LinuxCNC v2.9.6 Released
I've been refraining from commenting on this till now, but i have to, i would absolutely prohibit changing anything that affects Axis GUI in any way, shape or form, from other GUI's or anything else.
Axis is and should remain bullet proof, that is the main reason i use it on all my machines (over 40 by now).
Destroying basic functionality on Axis to fix something already broken in GmoccaPy is plain absurdity.
I can absolutely understand if it was a mistake, but from a bit of reading it does not seem to.
I really hope i am wrong...
15 Oct 2025 18:57 - 17 Oct 2025 14:55 #336514 by Aciera
Replied by Aciera on topic LinuxCNC v2.9.6 Released
So you think that I broke AxisGUI on purpose to fix something in Gmoccapy? Really?
I'm sorry to say but comments like these are what I would call 'plain absurdity'.
And just to warn you there is going to be yet another release because I screwed up fixing yet another bug.
Last edit: 17 Oct 2025 14:55 by Aciera.
15 Oct 2025 19:10 #336515 by tommylight
So it was a mistake, that is a huge relief.
And i was not aware who did it as i did not bother to check from frustration.
Thank you.
  • andypugh
  • Moderator
  • Moderator
16 Oct 2025 00:03 #336527 by andypugh
Replied by andypugh on topic LinuxCNC v2.9.6 Released
It came as a surprise to everyone, I think, that a fix for a preview bug in Gmoccapy caused the touch-off dialog in Axis to break.
I mean, who would even think to check that when testing the bugfix? It's about the most obscure interaction I have ever seen.
(And it only showed up if trying to touch-off to anything other than zero, too)
It came down to the fact that the Axis touch-off dialog parses the entry as G-code,and passes it through the G-code parser. (this is actually quite cool, you can touch-off to "sin[45]" if you want to.
But that relied on something in the startup sequence initialising something in the interpreter, and that, in turn, was messing up the Gmocapy (and others) graphical preview position. (specifically it was running STARTUP_GCODE every time, but only for the preview)
The fix was obviously good, but a side-effect was making the Axis touch-off work by accident..,
Time to create page: 0.688 seconds
