Forum Upgrade
- JT
- Thank you received: 617
20 Nov 2026 05:16 #350848
by JT
Forum Upgrade was created by JT
The forum upgrade will start Saturday, 11/21/2026 at 05:00 CST (UTC-6).
Two hours prior to the start a yellow banner will show up warning you to save your work and log off.
One hour prior to the start a red banner will show up warning you to save your work and log off.
At 05:00 CST the forum will be put into read only mode then shut down.
A snapshot will be taken of the forum then it will be powered up in read only mode. This will make sure no posts are lost.
You can continue to read and search the forum while the new droplet is being made.
Once the new droplet has been upgraded and tested I will do the DNS transfer which can take anywhere from a few minutes to a couple of hours.
When the DNS transfer is done a refresh will show the new forum ready to post into.
I want to thank everyone that donated to the project so we could have a better forum.
JT
JT
Time to create page: 0.359 seconds
