Re:Hardinge CHNC 1 Lathe
16 years 7 months ago #2210 by BigJohnT
Replied by BigJohnT on topic Re:Hardinge CHNC 1 Lathe
Hi Dan,
I'm not there yet, It is all moving but I need to work on the PID tuning and figure out what I need to look at on Hal Scope.
I'm closer than I've ever been.
16 years 7 months ago #2251 by BigJohnT
The X axis belt came in today so I got that up and running and homing so things are progressing nicely.
JT
16 years 7 months ago #2290 by BigJohnT
Well I made some good progress this morning and have the tool turret up and going.
I've attached my ladder file for those interested in how I did the ladder logic.
Attachment hardinge.gz not found
16 years 7 months ago #2320 by BigJohnT
SWEET! I actually made some chips on the Hardinge last night. It's not ready to run completely but close.
16 years 6 months ago - 16 years 6 months ago #2564 by BigJohnT
I've made a lot of progress on the CHNC and have made a few parts and some not so good parts as a learning experience. While scrounging through a machine graveyard I found a control panel with a bunch of AB selector switches in it. To my suprise there were three 4-position selectors. I installed them near the MPG and used the original legend plates even though I don't have a Y axis... this setup works so much better for quickly moving the turret to a touch off position. The only thing that does not work in this photo is the Feed Override Knob as it is a binary type and I can't figure out how to use that with EMC2. It sure would be nice to have it working...
image missing http://i47.photobucket.com/albums/f163/johnplctech/Hardinge/Controls/MPG.jpg
Last edit: 16 years 6 months ago by BigJohnT.
16 years 6 months ago #2570 by bigalex
Replied by bigalex on topic Re:Hardinge CHNC 1 Lathe
Hello John, what do yuo mean when you say this
"The only thing that does not work in this photo is the Feed Override Knob as it is a binary type and I can't figure out how to use that with EMC2".
Is the Feed Override Knob digitally coded in BCD or GRAY ?
If is coded as I say maybe you can decode it with ClassicLadder and manipulate the value for the use into an hal file,
bigalex :blink:
Time to create page: 0.692 seconds
