Robot
18 Dec 2011 08:13 #15795 by roboyoungster
Robot was created by roboyoungster
Hi, is it possible to use the EMC on a KUKA KRC 125 robot for MIG welding and plasma cutting?
www.kuka-robotics.com/en/solutions/solut...cle_transmission.htm
David
18 Dec 2011 09:28 #15797 by cncbasher
Replied by cncbasher on topic Re:Robot
yes you should be able to , but not a trivial and certianly not straight out the box conversion , their will be a fair amount of configuration required , and a steep learning curve
look at the Puma config files and take time to understand the principles , and learn Kinematics , a lot of setting up requires measurments of Arms and arc's and positional information
if you have the manuals they should help , actualy converting the Hardware will be the easy task , using Mesa IO cards and adapters , as you'll easy need all 9 axis in the end
and probaly more than one servo card , you need to know information on the positional encoders fitted and the servo drives and switches for limits of each Joint etc
but take your time , and it should work out fine , as all things do your homework first before ripping anything out
18 Dec 2011 10:00 #15798 by roboyoungster
Replied by roboyoungster on topic Re:Robot
Can I use also the same control/hardware?
18 Dec 2011 17:48 #15813 by cncbasher
i 'm not familiar with that particular model , but i would doubt you would be abe to use the origional control panel
although the motor drives and switches would be used ,
the panel shown will be very specific to it's use so the chances are low , it could be done but theirs a lot of work involved , fine if your into electronics
but a nightmare probably if your not .
is this a working machine .... ?? , what reason for changing to EMC ? ,
18 Dec 2011 18:48 #15816 by roboyoungster
That`s what I had aslo in mind to use only the motor drivers and switches.
The machine is working.
The reason is the simplicity of the EMC and because the original control is based on windows 95 with a implementation of XLM codes. Programming is not my strength on that base!
David
18 Dec 2011 19:40 #15818 by cncbasher
should be fine , but dont underestimate the work involved . if you have the manuals it should be painless to convert
programming may be another matter , you may perhaps need some components for welding capability etc later on
19 Dec 2011 11:19 #15836 by roboyoungster
Thank you for your inputs.
I`ll return with news.
David
25 Jan 2012 03:53 #17110 by happytriger2000
Replied by happytriger2000 on topic Re:Robot
Hello,
This is is my robot milling Poly:
It would be great if EMC2 could run Kuka robots or any other robot, but is going to take alot of effort.. I will be running EMC2 for my Mitsubishi Movemaster soon, 6 Dc servo driver + Motor.
25 Jan 2012 11:00 #17115 by andypugh
Replied by andypugh on topic Re:Robot
EMC2 already does run robots. There are specific kinematics modules for a small number of specific robots, and a general serial kinematics module for arbitrary robots.
linuxcnc.org/docs/html/man/man9/kins.9.html
Unfortunately it is an area that is not particularly well documented.
25 Jan 2012 12:33 #17120 by roboyoungster
Dear All
Thank you for the inputs.
Unfortunately I had some problems organazing the hardwares especially the motion control card but I found something interested:
www.automation.com.tw/common/entry.htm
Regards
