Servo Adapter Plates for Knee Mill Conversion
- jrcrane
08 Feb 2012 18:04 #17506
by jrcrane
Servo Adapter Plates for Knee Mill Conversion was created by jrcrane
Does anyone have drawings or models for servo adapter plates to fit X and Y axis on Brigdeport type knee mill? At one point I had these but cannot locate them at the moment.
Thanks,
Reg Crane
Thanks,
Reg Crane
- BigJohnT
- Thank you received: 1176
09 Feb 2012 18:17 #17530
by BigJohnT
Replied by BigJohnT on topic Re:Servo Adapter Plates for Knee Mill Conversion
Is this a mill that you lost the servos or one that still has never been converted to CNC?
- jrcrane
09 Feb 2012 19:02 #17531
by jrcrane
Replied by jrcrane on topic Re:Servo Adapter Plates for Knee Mill Conversion
Never been converted. Would like to utilize some Kollmorgren servos that we salvaged from a pc of automation.
Reg
Reg
- BigJohnT
09 Feb 2012 19:43 #17532
by BigJohnT
Does it have ball screws now?
My BP conversion with Anilam 1100m system uses belt reduction between the ball screws and the servos for X , Y and Z axes. Every different conversion kit would be different in design.
- jrcrane
09 Feb 2012 20:22 #17533
by jrcrane
This one does not have ball screws at the moment but we will purchase and install for this conversion. I will design our own mounting for the existing servos and use a reduction belt design. I want the Y axis motor behind and under the table and the X axis can be mounted on the outside of the mounting bracket. Haven't figured out the Z axis yet but we will.
Reg
Reg
- BigJohnT
09 Feb 2012 20:48 #17534
by BigJohnT
That is the way mine is done.
This is a photo of the front showing the Z axis. The servo drives the ball screw via a belt reduction. I can take more detailed photos of the innards if needed.
s47.photobucket.com/albums/f163/johnplct...current=HPIM0599.jpg
- jrcrane
10 Feb 2012 02:46 #17538
by jrcrane
John,
Good pic. I would like to see how the Z is mounted to the quill. If it would not be too much trouble for you, could you show me how it is mounted.
Thanks,
Reg
Thanks,
Reg
- Thank you received: 5002
10 Feb 2012 16:00 #17573
Replied by andypugh on topic Re:Servo Adapter Plates for Knee Mill Conversion
jrcrane wrote:
picasaweb.google.com/1081645046564043805...#5648298987857956962
(You can see the foundry pattern it was made from at the bottom of the photo)
This is the one I designed for my not-a-Bridgeport:I want the Y axis motor behind and under the table
- BigJohnT
10 Feb 2012 17:46 #17579
by BigJohnT
Here is a couple of photos of the Z.
gnipsel.com/shop/bpmill/images/bpmill01.jpg
gnipsel.com/shop/bpmill/images/bpmill02.jpg
- jrcrane
11 Feb 2012 01:35 #17590
by jrcrane
John,
Thanks for the pics of the inside. This really helps.
Reg
Reg
