Bridgeport Series II Interact 2 retrofit
- john_f
- Thank you received: 3
06 Feb 2010 16:42 #1794
by john_f
Bridgeport Series II Interact 2 retrofit was created by john_f
Here is a link to my recent retrofit on a 1987 Bridgeport Series II Interact 2 mill.
www.machineability.com/Bridgeport_series_II.html
- bezelchuck
08 Feb 2010 13:41 #1812
by bezelchuck
Replied by bezelchuck on topic Re:Bridgeport Series II Interact 2 retrofit
Great work !!!
A very professional looking installation. I'll be upgrading my Interact4 as soon as I'm done with the Hurco (which is dead as a dodo and so a priority) so will be studying the files you've put on your website. Many thanks.
Phil
Phil
- Gegsite
24 Apr 2010 20:38 #2684
by Gegsite
Replied by Gegsite on topic Re:Bridgeport Series II Interact 2 retrofit
Really cool!
RESPECT!
RESPECT!
- BigJohnT
- Thank you received: 1176
24 Apr 2010 21:18 #2690
by BigJohnT
Replied by BigJohnT on topic Re:Bridgeport Series II Interact 2 retrofit
Looking Good!
- sduqu2011
02 Mar 2011 01:06 #7525
by sduqu2011
Replied by sduqu2011 on topic Re:Bridgeport Series II Interact 2 retrofit
Great looking machine. We retrofitted a Bridgeport J-Head and like a lot of the ideas you have.
-Spencer
-Spencer
- aventtini
- Visitor
12 Jun 2015 01:43 #59716
by aventtini
Replied by aventtini on topic Re:Bridgeport Series II Interact 2 retrofit
Did you have any schematics on the EXE board i have a TNC155 that i want to get the TTL out
- john_f
13 Jun 2015 02:10 #59757
by john_f
Replied by john_f on topic Re:Bridgeport Series II Interact 2 retrofit
I don't have schematics. My controller was TNC 151. Here are some photos and some notes on the TTL signals.
TNC-151 analog board
The following user(s) said Thank You: LearningLinuxCNC
- aventtini
- Visitor
16 Jul 2015 02:08 #60640
by aventtini
Some updates we have a question on the last pic the 74L500 converts the signal from + to - ? and i see the schematic there is a Enable . Whats that stand for ? we have connected the TNC 155 board and we have got all the channels out but i understand from my friend that you have use that IC for inverting the signal to - from +
- john_f
16 Jul 2015 07:40 #60643
by john_f
For each encoder there is there are the quadrature signals A and B. Each encoder also has an Index pulse. Apparently Heidenhain used an enable signal to allow / not allow the index pulse. The enable signal came from the back plane connector. The 74LS00 is what is called a quad NAND gate. A NAND gate is a logic device that will output a H (High) for all combinations of the 2 input signals except when the 2 inputs are both H then the output will b L (low).
See truth table for NAND gate
. The Index pulse flows through the NAND gate before making its way to the connector. Since I wanted to only use the signals on the connector I had to supply the enable signal by installing a jumper for each of the enable signals to a logic H. H is 5V in this case. The jumpers are show in image_2685. So now the index pulses for each encoder can be taken from the connector according to IMAG0719. You are also correct that the index pulse is also inverted as it goes through the NAND gate (74LS00).
I hope this helps
I hope this helps
