Drill probleme
- Frederik
13 Jul 2012 08:08 #21863
by Frederik
Drill probleme was created by Frederik
I have a problem, when I drill holes with my V90, the drag drill down too hard in the tackle, even if drilling is sharp.
Do you have any idea.
I run with Google sketchucam and emc2.
- cncbasher
- Thank you received: 288
13 Jul 2012 10:04 #21866
by cncbasher
Replied by cncbasher on topic Re:Drill probleme
give us an idea of the size of drill you are using , feedrate and type of spindle , and what material you are drilling , it could be your running too slow or wrong feed rate etc
- Frederik
13 Jul 2012 20:07 #21920
by Frederik
Replied by Frederik on topic Re:Drill probleme
I think I've found the problem, I am using a Bosch machine, but if I lift it slightly, it helps, so I will try to try with no counterweight.
Time to create page: 0.047 seconds
