Use LinuxCNC with a 3d-joystick?
- pfefferhaxen
I want to buy a 3 axis (3d) joystick with USB connection.
But before I invest the money, I would like to know, if its possible to control linuxcnc with a joystick (no joypad)?
Is it the same way to configure the USB-joystick like the way in Big John T´s description for a joypad here wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant ?
Thank you.
Greetings from Germany,
Norbert
- Thank you received: 4995
I would expect so.
Does the device come with drivers (it is a good sign if it doesn't) and do the docs mention "USB HID" anywhere?
- pfefferhaxen
I would expect so.
I´ll don´t buy it yet, but google means, that the joystick I choosed works without any extra drivers with linux.
Its this one www.amazon.com/Thrustmaster-T-Flight-Sti...T.Flight+Stick+X+USB
I think, I should order it, and if it doesn´t work in can send it back to amazon.de within 2 weeks.
What do you think?
Best regards
Norbert
I would consider that cheap enough to try and then just put at the back of a cupboard if it doesn't workIts this one www.amazon.com/Thrustmaster-T-Flight-Sti...T.Flight+Stick+X+USB
Interesting that it costs $29, or €28, or £29 depending on which Amazon you go to. That seems rather unrelated to exchange rates.
- pfefferhaxen
I´m not sure what is more comfortable for manual control: Joystick or gamepad? Has someone experiences?
First I thougt a Joystick will be better because in my opinion the control is more accurate, but in all youtube-videos and blog-reports they use gamepads. Are there special reasons for gamepads?
You can walk around with a gamepad, and stand where you can see what you need to see. You can also just about work them one-handed.First I thougt a Joystick will be better because in my opinion the control is more accurate, but in all youtube-videos and blog-reports they use gamepads. Are there special reasons for gamepads?
A joystick needs a surface to sit on.
- pfefferhaxen
I will think about it tomorrow and then I order something, maybe Joystick, maybe gamepad, I will see.
Now its midnight in germany, and I will stop posting for today. The bed is calling...
See you later
- BigJohnT
- Thank you received: 1176
I know if you want accurate movement you need to do like Rick did and add incremental jog to the gamepad or the joystick. I don't find them terrible for positioning my plasma, but I woudn't use either in continuous mode to touch off a tool.
- pfefferhaxen
It should work well with Ubuntu 10.04 and I will test it with my CNC.
If there are problems with the joypad, I maybe will buy me a joystick and try this.
Thanks for your help!
