Raster Laser Machine only using GCode
- cncbasher
- Thank you received: 288
06 Dec 2012 05:57 #27263
by cncbasher
Replied by cncbasher on topic Raster Laser Machine only using GCode
post your hal files and changes etc , i need to see what you are working with , the test files i posted do work well for raster.
but i do not know how you are triggering the laser etc , or your electronics etc ,
can you post a video etc , it could help
- Thank you received: 4995
06 Dec 2012 09:40 #27279
To be honest, the motors in that clip do not sound happy.
Replied by andypugh on topic Raster Laser Machine only using GCode
- diegoroman17
07 Dec 2012 06:20 #27351
by diegoroman17
Replied by diegoroman17 on topic Raster Laser Machine only using GCode
- diegoroman17
07 Dec 2012 06:23 #27352
by diegoroman17
I try up a video but appear in blank.
The changes file is:
The hal file is:
The hal file is:
- diegoroman17
14 Dec 2012 08:10 #27709
by diegoroman17
this is the video
14 Dec 2012 08:17 #27710
I don't think you can upload a video, but you can insert a link to a YouTube video.this is the video
- diegoroman17
14 Dec 2012 08:36 - 14 Dec 2012 08:38 #27711
by diegoroman17
Last edit: 14 Dec 2012 08:38 by diegoroman17. Reason: Error in video
14 Dec 2012 08:45 #27712
Are you still using G0 and G1 moves? That will make it show correctly in the preview (because rapids and feeds get shown in different colours) but mixing G1 and G0 will never give smooth movement.
How are you controlling laser intensity now? (S, M67, Z?)
My raster
- diegoroman17
14 Dec 2012 08:49 #27713
by diegoroman17
Yes. I am controling with M67. But how I can do smooth movement and have preview at the same time?
14 Dec 2012 19:34 #27721
If you accept for the moment that you can't have preview _and_ smooth movement, can you at least confirm that you can have smooth movement by replacing all the G0 moves by G1?
I think you probably also need "overscan" moves to have a constant speed across the image area.
To have preview you would need to make the preview widget plot a different colour according to the value of M67. This might actually not be very difficult, but I am not the chap who would know how to do it.
Time to create page: 0.083 seconds
