- Thank you received: 126
Convert from Anilam Crusader M to EMC 2
- jmelson
10 years 5 months ago #74487
by jmelson
Another option is to use the Pico Systems PWM servo amps and PWM controller. (They can also be used with Mesa controller boards that can output PWM, if you already have the Mesa board.)
Jon
Replied by jmelson on topic Convert from Anilam Crusader M to EMC 2
FloppyDisk wrote: OT-CNC,
One thing I forgot to mention is that when shopping for servo drive replacements (copley, AMC, etc), patience is your friend. I see that some Copley 423's are for sale for > $400, however, if you wait you might get them less than $100 each, just depends.
Jon
- OT-CNC
- Thank you received: 75
10 years 5 months ago #74522
by OT-CNC
Replied by OT-CNC on topic Convert from Anilam Crusader M to EMC 2
Jon,
Thanks for the info.
I assume your boards don't read the tachometer?
- jmelson
10 years 5 months ago #75101
by jmelson
Right, our PWM system doesn't need the tach. And, if using our analog system (the PPMC) then the tachs only go to the servo amps, not the control.
Jon
Jon
Time to create page: 0.207 seconds
