cincinnati axis spindle question
- jlviloria
- Thank you received: 12
16 Feb 2013 04:22 #30152
by jlviloria
cincinnati axis spindle question was created by jlviloria
I'm working on a lathe cincinnati, which has the option of tool. My question right now is how to set the spindle to work as the C axis
is that with M19 spindle orient, but how do you place him degrees to the spindle.? example: C30, C90.
- emcPT
- Thank you received: 139
16 Feb 2013 06:12 #30156
by emcPT
Replied by emcPT on topic cincinnati axis spindle question
It will depend on how the spindle is controlled. What kind of motor is running the spindle?
Do you currently already use linuxcnc on that lathe?
The following user(s) said Thank You: jlviloria
- jlviloria
18 Feb 2013 21:33 #30275
by jlviloria
Replied by jlviloria on topic cincinnati axis spindle question
Thanks for your answer.
I realized I had not put any motor information.
It is a DC motor, 50HP Reliance brand, and the machine is controlled by linuxcnc.
linuxcnc.org/index.php/english/forum/30-...cinnati-milacron-12c
I hope you can help me, thank you very much again.
- emcPT
19 Feb 2013 20:17 - 19 Feb 2013 20:22 #30316
by emcPT
Currently what drives the motor is in good working condition?
Can you inform what drives the motor?
If it is in good working condition maybe you still can use all the existing hardware.
Where are you located? Spain? Mexico?
Filipe
Filipe
Last edit: 19 Feb 2013 20:22 by emcPT.
- jlviloria
19 Feb 2013 21:59 #30319
by jlviloria
Filip thanks for your answer.
The DC motor controlled by a variable speed Reliance. is in pefect condition.
The question is how to control to make it work with M19, for working with power tools.
I'm in Colombia.
thanks
I'm in Colombia.
thanks
- emcPT
20 Feb 2013 06:31 #30338
by emcPT
I am afraid I cannot help you. I am rather new here and I am trying also to do a retrofit.
In my case I am way back than you as I do not even have a spindle running (the original spindle drive was damaged), but my machine also have live tooling.
Maybe someone will give you that info as there are members that know a lot.
- Thank you received: 4995
25 Feb 2013 03:51 #30535
You would basically use two different PID controllers, one for normal spindle mode, commanded by motion.spindle-speed-out (or motion.spindle-speed-out-rps) and another commanded by the motion.spindle-orient-angle pin.
You would then use a mux2 component to decide which PID output is sent to the spindle motor controller. The mux2 select would be linked to the motion.spindle-orient pin.
This gives closed-loop control of spindle speed, and closed-loop position control.
There is a component called "orient" that is intended to help. www.linuxcnc.org/docs/html/man/man9/orient.9.html but I think you still need the other components I suggested.
It is probably a good idea to disable the inactive PID controller when the other is doing the job.
I keep meaning to set this system up with my mill, but I haven't done so yet.
Replied by andypugh on topic cincinnati axis spindle question
I think this needs to be done with a bit of cleverness in HAL.I'm working on a lathe cincinnati, which has the option of tool. My question right now is how to set the spindle to work as the C axis
- mhaberler
- Thank you received: 11
26 Feb 2013 21:51 #30611
by mhaberler
Replied by mhaberler on topic cincinnati axis spindle question
there is also a matching demo configuration (sim mode):
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...05d2d6eb0b7751cd07e3
- Michael
- Michael
- jlviloria
05 Mar 2013 23:54 #30928
by jlviloria
how he would control the angle or want to make an contour on the machine, if equipped with a DC motor? not require a servomotor? or you can control a DC motor that way?
Thanks for advance
Thanks for advance
05 Mar 2013 23:58 #30929
I am working on a sample lathe XZC config at the moment. Might have it working tonight.
If the spindle has an encoder then the motor _is_ a servo.how he would control the angle or want to make an contour on the machine, if equipped with a DC motor? not require a servomotor? or you can control a DC motor that way?
Time to create page: 0.076 seconds
