Punch press retrofit
- Holycross
18 Mar 2013 14:12 #31533
by Holycross
Punch press retrofit was created by Holycross
Are there any examples of retrofitting a cnc punch press.
Looking into the possibility of retrofitting a 60 ton Q-Tec press.
Mark
Mark
- Thank you received: 4994
19 Mar 2013 04:21 #31556
Replied by andypugh on topic Punch press retrofit
I don't know of any examples, but I can't imagine any real problems.
What does punch-press G-code look like? Is there an implicit punch after every move?
- Holycross
19 Mar 2013 12:02 #31576
by Holycross
Replied by Holycross on topic Punch press retrofit
Andy,
Not sure what the code looks like. Imagine move to position then use an m-code to fire the punch.
Just starting out looking into the retrofit possiblities.
Thanks,
Mark
Thanks,
Mark
19 Mar 2013 19:41 #31589
en.wikipedia.org/wiki/Excellon
It probably wants to toolchange on the T rather than wait for an M6 too.
That would work, but I can imagine that it might be more like PCB drilling code, where there is an implicit punch at the end of every move.Imagine move to position then use an m-code to fire the punch.
Time to create page: 0.530 seconds
